A Tube, The Wooden Kind
While we aren’t heavy-duty woodworkers, we occasionally make some sawdust as part of a project, and we admire people who know how to make wood and do what they want. We were surprised when [Newton Makes] showed a wooden dowel that was quite long and was mostly hollow. The wall was thin, the hole was perfectly centered, and he claimed he did not use a drill to produce it. Check it out in the video below and see what you think.
We don’t want to spoil the surprise, but we can tell you that making something that long with a drill or even a drill press would be very difficult. The problem is that drills have runout — the bits are usually not totally centered, so the bit doesn’t spin like you think it does. Instead, it spins and rotates around a small circle.
At the chuck, that small circle isn’t a big deal. But the further you get from the chuck, the bigger the runout circle gets. So a 10 cm long drill bit won’t amplify the runout much, but a 100 cm bit will make more of a cone shape unless the drill press is very accurate.
Take your guess, go watch the video, then come back and tell us if you guessed correctly. We didn’t. If you want to get better at woodworking, we can help. If you get really good, you can bend wood to your will.
21 thoughts on “A Tube, The Wooden Kind
    1. I come here to read a summary of interesting things, not as a redirect to go watch a video somewhere else. Thank you for summarizing how it works better than the click-bait article above.
  1. My 3d printing brain kicked in and my first guess (if it’s not drilled or lathed) was split it in half.
    It’s an interesting way of looking at a problem and any new approach or perspective is good, especially if it’s something that can add to your physical or mental (or emotional/behavioural) toolkit.
  2. Didn’t watch the video, but sounds like a molding cutter and wood glue got the job done.
    Would come out a might charred, but it seems like a laser ought to (eventually) cut a tube like this, assuming the focus can be moved that much, (or doesn’t need to move at all because it’s a perfect beam.)
  3. The problem when trying to drill a hole into wood isn’t so much the run-out as it is the wood grain, which has areas of varying hardness that tend to push the drill bit around. With a stiff drill bit and a firmly clamped work piece, this usually isn’t an issue. When a drill bit is long and skinny, though, it’s going to have some flex and let itself get pushed around some.
  4. There is a bit called a gun drill that has a round shank and a single long flute. It fits closely in the hole you’re drilling so it doesn’t wobble. The next bit of technique is to use an oversized blank and then turn the outside concentric to the hole.
Leave a Reply to make piece not warCancel reply
