The Camp Snap is a simple fixed-focus digital camera with only an optical viewfinder and a shot counter, which has become a surprise hit among photography enthusiasts for its similarity to a disposable film camera. [Snappiness] has one, and also having a liking for waist-level viewfinders as found on twin-lens reflex cameras, decided to make a new Camp Snap with a waist-level viewfinder. It’s a digital twin-lens reflex camera, of sorts.
Inside the Camp Snap is the little webcam module we’ve come to expect from these cameras, coupled with the usual microcontroller PCB that does the work of saving to SD card. It’s not an ESP32, but if you’ve ever played with an ESP32-CAM board you’re on a similar track. He creates a 3D-printed TLR-style case designed to take the PCB and mount the camera module centrally, with ribbon cable extensions taking care of placement for the other controls. The viewfinder meanwhile uses a lens, a mirror, and a Fresnel lens, and if you think this might look a little familiar it’s because he’s based it upon his previous clip-on viewfinder project.
The result, with an added “Snappiflex” logo and filter ring, is a rather nice-looking camera, and while it will preserve the dubious quality of the Camp Snap, it will certainly make the process of using the camera a lot more fun. We think these cheap cameras, and particular their even less expensive AliExpress cousins, have plenty of hacking potential as yet untapped, and we’re keen to see more work with them. The full video is below the break.
Maybe you can try with raspberry pi, as a base. The camera sensors are nice.
GP
ooooh…. he did state the camera was a limiting factor in the build due to how short it was.. using the pi as you suggest would be great given the sensor is obviously well documented, and various lengths are available cable wise
This is more properly a “pseudo TLR” (like the Ensign Ful-Vue, Voighlander Brillant, Kodak Duaflex, etc), as it does not project the viewing image onto a ground glass as with a ‘true’ TLR*, but creates an aerial image. The difference being that if you move your head around and look at the projected image of a TLR finder, the image will stay the same, objects in the image staying ‘fixed’ on the ground glass. Framing will be the same no matter how you look at the finder image But for a ‘brilliant finder’ as used here, moving your head around with the camera stationary will cause the finder image to also move around. As you move your head, the framing changes, so there is only one location you can look through the finder and see the correct image framing, but lots of locations from which you can look through the finder and see completely the wrong framing.
Where both the taking lens and viewing lens project an identical image onto a flat plane, which for the taking lens happens to be where the film is placed and for the viewing lens where the ground glass is placed. Since the viewing and taking lens are the same specification of lens (same focal length, same maximum aperture, and in non-cheap TLRs same lens formula so same aberrations) this means that the projected images are the same barring the slight physical offset between optical axes, so what you see (on the ground glass) is what you get (on the film plane).
The ‘reflex’ bit of ‘Twin Lens Reflex’ just means there’s a mirror somewhere in the optical path.
