C+P: Combining The Usefulness Of C With The Excellence Of Prolog
In a move that will absolutely not over-excite anyone, nor lead to any heated arguments, [needleful] posits that their C Plus Prolog (C+P for short) programming language is the best possible language ever. This is due to it combining the best of the only good programming language (Prolog) with the best of the only useful programming language (C). Although the resulting mash-up syntax that results may trigger Objective-C flashbacks, it’s actually valid SWI-Prolog, that is subsequently converted to C for compilation.
Language flamewars aside, the motivation for C+P as explained in the project’s README was mostly the exploring of macros in a system programming language. More specifically, by implementing a language-within-a-language you can add just about any compile-time feature you want including – as demonstrated in C+P – a form of generics. Even as a way to have a bit of fun, C+P comes dangerously close to being a functional prototype. Its main flaw is probably the lack of validation and error messages, which likely leads to broken C being generated.
Also mentioned are the Nim and Haxe languages which can be compiled (transpiled) to C or C++, which is somewhat of a similar idea as C+P, as well as cmacro (based on Common Lisp) and the D language.
8 thoughts on “C+P: Combining The Usefulness Of C With The Excellence Of Prolog
  1. Excellent! It’s a really intriguing idea and having programmed both Prolog and C I feel qualified to be enthusiastic.
    Though name-wise I’d suggest PPPC (Prolog Pre Processor for C – and both PPP and PPC were already taken)
Leave a Reply to John GarrettCancel reply
