The iMac G3 is an absolute icon of industrial design, as (or perhaps more) era-defining than the Mac Classic before it. In the modern day, if your old iMac even boots, well, you can’t do much with it. [Rick Norcross] got a hold of a dead (hopefully irreparable) specimen, and stuffed a modern PC inside of it.
From the outside, it’s suprizingly hard to tell. Of course the CRT had to go, replaced with a 15″ ELO panel that fits well after being de-bezeled. (If its resolution is only 1024 x 768, well, it’s also only 15″, and that pixel density matches the case.) An M-ATX motherboard squeezes right in, above a modular PSU. Cooling comes from a 140 mm case fan placed under the original handle. Of course you can’t have an old Mac without a startup chime, and [Rick] obliges by including an Adafruit FX board wired to the internal speakers, set to chime on power-up while the PC components are booting.
These sorts of mods have proven controversial in the past– certainly there’s good reason to want to preserve aging hardware–but perhaps with this generation of iMac it won’t raise the same ire as when someone guts a Mac Classic. We’ve seen the same treatment given to a G4 iMac, but somehow the lamp doesn’t quite have the same place in our hearts as the redoubtable jellybean.
Neat case, shame the CRT was thrown out
Yeah, think same. Unfortunately, people nolonger know how to handle CRT technology.
If only AMOLED panels or laser-based panels would be available finally.
The technological progress is so slow. LCD, TFT.. Such vintage technologies. Sigh.
They were around when I was a kid, already.
Well, very early in my career I learned how to repair CRT televisions and monitors, I’d have preferred to keep it too, but they take up so much space and are pretty much all knackered now with low emission, soggy focus and filled with unobtainable parts so even if the scan rates were compatible, I’d probably accept a vaguely period correct resolution and format TFT.
If the CRT was already bad, no loss there as it’s next to impossible to repair CRT. If it was still working, I would have kept it in case someone local needs a replacement CRT
hell if it worked id put it on ebay. projects need funding.
I have a similar machine, mine is broken too, due to the heat and design issues they are all basically dying and with no schematics at hand if the CRT driving board is toast (like mine) you are pretty limited, my next step is to figure out if I can fit one of these CRT boards from aliexpress in it
“The iMac G3 is an absolute icon of industrial design” that’s up for debate, but it’s shape and colors are certainly fun and recognizable. But for many people of today, it looks like a silly prison TV with a build in DVD player and a keyboard.
A real absolute icon is the “floppy disk” or 3.5″ diskette, it is not only iconic as representing the era it was used in, it is still used as an actual icon today. The irony is that the G3 did not support that icon by default, forcing users to buy an external drive to suit their needs. Ruining the “clean desktop policy” of the G3 concept. The added irony is that the “floppy” is still around and the revolutionary CD the G3 hosted is gradually being forgotten.
Not quite. The iMac gave birth to USB floppy drives, essentially! 😃
USB floppy drive came along a few years after some Macintosh ditched floppy disk drive. I got a Powerbook Duo 280c, the Duo line were the first without internal disk drive.
That was rather normal for notebooks, though.
The floppy has gone past iconic. Centuries hence, when the last living cyborg on the edge of the oort cloud uploads their consciousness into holographic crystal media, the final thought recorded by the process will be “why does the button look like that?” 💾
Yet, ironically, the CD is still in production and the floppy is not.
Petition to change the save icon to a CD? :D
I’m in the middle of putting a custom computer into an original G3 iBook case at the moment. I guess there’s something about these old Apple designs that’s really A-peal-ing!
I’ll show myself out…
Since most of the modern components are smaller now, you should have plenty of room to put even a whole Mac Mini in there.
The sad part is if you had to buy an ELO screen today even a 4:3 model would exceed the cost of the mac originally, those things are commercial grade and they darn well let you know it! I think one of the last ones I bought for work new was like 21 inch 16:9×1080 with touch screen and it was approaching 3 grand before postage
I built a retro gaming PC from one of these last year. It’s powered by a Raspberry Pi and I retained the original CRT display, speakers, and power button. The Pi is mounted to a 3d printed holder that sits where the original I/O board was, giving access to USB ports.
Quite a nice project but he could have atleast tried to get the internal crt working or even swap the boards for one of those from aliexpress cause they can be cheap. Its basically just repurposing the shell the same way as saying ‘i got doom running on a preg test’ and only using the shell of the device and swapping all the electronics and the rest. Actionretro on youtube has got an old crt to work and he put it in an old macintosh 68k and while he swapped out the rest of the boards, he did still put in a CRT and he put in a mac mini (even when he first wanted to consider an LCD). I would have more liked it to be this way
Still sad the CRT bit it. I probably wouldn’t swap CRT for LCD in most form factors. Not sure where it would be appreciated, maybe a digital scope?
Glad to see the ingenuity, at least it’s a home user, and not a museum misrepresenting the past (if an old PC needs a display, leave the dead CRT there and plug in an obvious LCD screen to show the output.
i think if you can recycle mass produced e-waste its a good thing. i dont think the imac is sufficiently retro so as to go about preserving every scrap of one as an archeological artifact (that becomes important at some point, but not just yet). second i used them at school when they were new, and they were crap. the only thing they had going for them was their asthetic, and preserving the case keeps that while making it more useful than a dust magnet in the corner of a nerd den. i have fonder memories of the mac se and apple 2s (and the ti99 i lifted when i got the job of cleaning out the shed as part of a detention detail) they seemed to have in abundance even though they were already 10-20 years old when i went to school.
besides the case is usually the last thing to go (ive got cases from machines i built 20 years ago long after the computers they housed gave up the ghost). other people have machines they want to restore and so long as you put the known working components up for sale on ebay or what not, you are actually providing a resource to other retro enthusiasts while also reducing e-waste.
