From Burnt To Brilliant: A Toaster’s Makeover
Air Fryer rPi upgrade
Appliances fail, but that doesn’t mean it’s the end for them. This impressive hack from [solopilot] shows the results possible when not just fixing but also improving upon its original form. The toaster’s failed function selector switch presented an opportunity to add smart features to the function selection and refine control over its various settings.
Before upgrading the toaster, [solopilot] first had to access its components, which is no trivial task with many modern appliances. Photos document his process of diving into the toaster, exposing all the internals to enable the upgrade. Once everything was accessible, some reverse engineering was required to understand how the failed function selector controlled the half-dozen devices it was wired to.
Toaster App GuiNext came the plan for the upgrades—a long list that included precise temperature control and the ability to send an SMS showing the state of your meal. A Raspberry Pi Zero, a solid-state relay, a relay control board, and a thermocouple were added to the toaster, unlocking far more capability and control than it had originally. Some tuning is required to fully enable these new features and to dial in the precision this once run-of-the-mill toaster is now capable of.
The work wasn’t limited to the toaster itself. [solopilot] also seized the opportunity to create an Android app with speech recognition to control his now one-of-a-kind Cuisinart. It’s probably safe to say his TOA-60 is currently the smartest toaster in the world. If you check out his documentation, you’ll find all the pinouts, circuits, code, and logic explanations needed to add serious improvements to your own toaster. We’ve featured several other toaster oven projects over the years, most of which have focused on turning them into reflow ovens, so it’s exciting to see one aimed at improving upon its original design.
26 thoughts on “From Burnt To Brilliant: A Toaster’s Makeover
    1. :) … Me too…. I’ll stick with the dial for timer and let it pop when done, or check, and manually pop if getting to done :) ! No gimmicks. No internet connection, no blue tooth connection. Simple is as simple does :) .
      But hey, if robotizing your toaster is your game … enjoy!! Next up is add wings and make it a flying toaster. Of wait, M$ did that I think with a screen saver already :) .
  1. I have a different model, and the selection dial went within a year. Seems like a design flaw putting the electronics above the heating elements. I don’t want a web server, but I should probably fix it.
  2. The Internet of Things has officially hit peak stupid, courtesy of this smart toaster
    Griffin Technology wants to sell you on the idea of a smart toaster. We’re increasingly sold on the idea of living on a remote island far away from companies that think slapping Wi-Fi and an LCD on to already-functional kitchen hardware constitutes some meaningful advance in the human condition.
    January 5, 2017
    https://www.extremetech.com/electronics/242169-internet-things-officially-hit-peak-stupid-courtesy-smart-toaster-griffin-technology
    Just evenly toasting toast should be the goal. I had a friend point out his expensive toaster. It didn’t toast any more evenly than mine which is not horrible, but not perfect. I looked inside his and it had the same crappy, probably Chinese nichrome heating element plate that mine has and every other toaster I’ve seen has.
Leave a Reply to PaulCancel reply
