Eulogy For The Satellite Phone
We take it for granted that we almost always have cell service, no matter where you go around town. But there are places — the desert, the forest, or the ocean — where you might not have cell service. In addition, there are certain jobs where you must be able to make a call even if the cell towers are down, for example, after a hurricane. Recently, a combination of technological advancements has made it possible for your ordinary cell phone to connect to a satellite for at least some kind of service. But before that, you needed a satellite phone.
On TV and in movies, these are simple. You pull out your cell phone that has a bulkier-than-usual antenna, and you make a call. But the real-life version is quite different. While some satellite phones were connected to something like a ship, I’m going to consider a satellite phone, for the purpose of this post, to be a handheld device that can make calls.
History
Satellites have been relaying phone calls for a very long time. Early satellites carried voice transmissions in the late 1950s. But it would be 1979 before Inmarsat would provide MARISAT for phone calls from sea. It was clear that the cost of operating a truly global satellite phone system would be too high for any single country, but it would be a boon for ships at sea.
Inmarsat, started as a UN organization to create a satellite network for naval operations. It would grow to operate 15 satellites and become a private British-based company in 1998. However, by the late 1990s, there were competing companies like Thuraya, Iridium, and GlobalStar.
An IsatPhone-Pro (CC-BY-SA-3.0 by [Klaus Därr])
The first commercial satellite phone call was in 1976. The oil platform “Deep Sea Explorer” had a call with Phillips Petroleum in Oklahoma from the coast of Madagascar. Keep in mind that these early systems were not what we think of as mobile phones. They were more like portable ground stations, often with large antennas.
For example, here was part of a press release for a 1989 satellite terminal:
…small enough to fit into a standard suitcase. The TCS-9200 satellite terminal weighs 70lb and can be used to send voice, facsimile and still photographs… The TCS-9200 starts at $53,000, while Inmarsat charges are $7 to $10 per minute.
Keep in mind, too, that in addition to the briefcase, you needed an antenna. If you were lucky, your antenna folded up and, when deployed, looked a lot like an upside-down umbrella.
However, Iridium launched specifically to bring a handheld satellite phone service to the market. The first call? In late 1998, U.S. Vice President Al Gore dialed Gilbert Grosvenor, the great-grandson of Alexander Graham Bell. The phones looked like very big “brick” phones with a very large antenna that swung out.
Of course, all of this was during the Cold War, so the USSR also had its own satellite systems: Volna and Morya, in addition to military satellites.
Location, Location, Location
The earliest satellites made one orbit of the Earth each day, which means they orbit at a very specific height. Higher orbits would cause the Earth to appear to move under the satellite, while lower orbits would have the satellite racing around the Earth.
That means that, from the ground, it looks like they never move. This gives reasonable coverage as long as you can “see” the satellite in the sky. However, it means you need better transmitters, receivers, and antennas.
Iridium satellites are always on the move, but blanket the earth.
This is how Inmarsat and Thuraya worked. Unless there is some special arrangement, a geosynchronous satellite only covers about 40% of the Earth.
Getting a satellite into a high orbit is challenging, and there are only so many “slots” at the exact orbit required to be geosynchronous available.  That’s why other companies like Iridium and Globalstar wanted an alternative.
That alternative is to have satellites in lower orbits. It is easier to talk to them, and you can blanket the Earth. However, for full coverage of the globe, you need at least 40 or 50 satellites.
The system is also more complex. Each satellite is only overhead for a few minutes, so you have to switch between orbiting “cell towers” all the time. If there are enough satellites, it can be an advantage because you might get blocked from one satellite by, say, a mountain, and just pick up a different one instead.
Globalstar used 48 satellites, but couldn’t cover the poles. They eventually switched to a constellation of 24 satellites. Iridium, on the other hand, operates 66 satellites and claims to cover the entire globe. The satellites can beam signals to the Earth or each other.
The Problems
There are a variety of issues with most, if not all, satellite phones. First, geosynchronous satellites won’t work if you are too far North or South since the satellite will be so low, you’ll bump into things like trees and mountains. Of course, they don’t work if you are on the wrong side of the world, either, unless there is a network of them.
Getting a signal indoors is tricky. Sometimes, it is tricky outdoors, too. And this isn’t cheap. Prices vary, but soon after the release, phones started at around $1,300, and then you paid $7 a minute to talk. The geosynchronous satellites, in particular, are subject to getting blocked momentarily by just about anything. The same can happen if you have too few satellites in the sky above you.
Modern pricing is a bit harder to figure out because of all the different plans. However, expect to pay between $50 and $150 a month, plus per-minute charges ranging from $0.25 to $1.50 per minute. In general, networks with less coverage are cheaper than those that work everywhere. Text messages are extra. So, of course, is data.
If you want to see what it really looked like to use a 1990-era Iridium phone, check out [saveitforparts] video below.
If you prefer to see an older non-phone system, check him out with an even older Inmarsat station in this video:
So it is no wonder these never caught on with the mass market. We expect that if providers can link normal cell phones to a satellite network, these older systems will fall by the wayside, at least for voice communications. Or, maybe hacker use will get cheaper. We can hope, right?
54 thoughts on “Eulogy For The Satellite Phone
    1. not just new. existing phones. iphone 14 and later. also Android phones. it’s wild how fast this came to be. it’s almost impossible to get lost now
      1. Yup I nearly got a Garmin sat phone recently before realising I had the functionality I wanted in the old phone sitting in my drawer.
      2. It also is a reminder that they can now track and hack and target you from the other side of the world.
        I mean many people were assassinated already with the military version plotting their position, but now it’s even more easy and global.
  1. IMHO, better speed up, China is ALREADY testing 6G (satellite-based comms) and have we had proper planning, we’d be experimenting with 7G (quantum entanglement networks – no need for the satellites per se). Sadly, US is not in the position to speed up R&D that’s needed.
    1. As far as retiring older phone satellites go – they came at the wrong time (at the end of the first Cold War) and it was about to happen anyway. I am actually surprised Iridium was even kept afloat that long, already outdated when it was launched, and in all fairness, it looked more like “reusing surplus/declassified military stuffs” than real for-profit thing. Pricing was not exactly affordable back then, and it is still too expensive to be of use to the average Sam’s needs.
      Regardless, as mentioned, 7G looks more promising, lest unexpected technological hurdle presents itself. That nobody will be able to spy on anyone else if 7G becomes affordable/doable is not something anyone can control, and the bad guys will be using it just the same, ahead of anyone else, so I see no reasons why this cannot happen sooner than later.
      1. The ‘g’ designations are arbitrary indications of cellular tech generations created as marketing fodder by telecoms, pretty much unrelated to the actual technologies used.
        Idk where you get the idea that satellites are “6g” or entangled comms are “7g”
      2. The Iridium constellation was saved by DoD among others because while it got cost ineffective for phone service, there are some things it did better than anything else and even if they were obsolete a lot of money and engineering had gone into creating the constellation. For awhile they were the go-to solution for must be worldwide small packet data links to remote equipment, and for sufficiently remote and inaccessible devices even cost effective. I remember reading that an Arduino shield was available and costs for 1K data packets were in the dime to quarter range. Which sounds outrageous in an era where we think nothing of downloading gigabyte movies, but would have seemed miraculous in the 1990’s.
        1. Iridium modems are still cost-effective in at least some niche applications. South Pole Station runs some for emergency communications, and some of the experiments run their own for 24/7 real-time data and monitoring (e.g. real-time follow-up alerts from the IceCube Neutrino Observatory). The station has DSCS and TDRSS coverage, but not 24/7. Starlink was trialed at one point and I think was both too spotty at −90° as well as the modems being too noisy in RF for long-term use around the radio-sensitive experiments.
    2. Satellite comms are more expensive, worse throughput and harder to implement.
      As the article states they were really only useful at sea or the poles
    3. Quantum entanglement and quantum communications are two entirely different things.
      Quantum entanglement relates to paired atoms or photons that always share the same quantum state. Quantum communications relates to a communication medium that uses the minimum energy such that if the communication channel is tapped or monitored, it is no longer viable (to either the user or the interceptor).
      1. “paired atoms or photons that always share the same quantum state”
        I’m afraid that the “always” in that sentence is going to reinforce the misconception that you are trying to repair.
        Perhaps something like “…that when measured will be found to correlate, but that have to causative influence upon each other.”
    4. Common misconception – quantum entanglement doesn’t work as a wireless communication method; you cannot send information faster than light with it (because that would go against the laws of physics as we know it). The idea is that if one end of a quantum entangled pair collapses, the other does as well and the way they collapse is correlated. However, you cannot influence the way they collapse, so you cannot send any information that way. You can use it for encryption: a heap of quantum-entangled particles can effectively generate a random encryption key in two places at the same time that is impossible to know before the collapse, and if an attacker makes it collapse beforehand, you will notice it. But it cannot used as a communication method by itself.
  2. Well seeing as iridium phones are L-band, I wonder are they good parts sources to make 23cm amateur radio gear?
    1. Why bother? Isn’t 23cm ham band being considered almost dead, anyway? 😟
      As far as I heard, the last new 23cm capable ansceivers were sold over 25 years ago.
      So hams interested in it need either SDRs or vintage radios, I guess.
        1. But you won’t find a conversation partner on 23cm, probably.
          Unless you meet up with a fellow ham friend.
          Or if an Amateur Television (ATV) relays is in your neighborhood,
          you might be able to listen/watch a conversation on 23cm.
          1. I am in Australia. 23cm is very busy. Loads of action on the Chatswood 23cm FM repeater here in Sydney Australia.
            Also activity in 1296.100MHz USB.
            Earth Moon Earth amateur 23cm is also very active.
          2. guys are working earth-moon-earth on 23cm and a little repeater action, but yea not that much action on 23cm voice , let me know if your near Modesto and we can try SSB , some ham sat recordings on the page link below. even one recording working 1.2ghz over the sat.
    1. Intelsat, as far as I know, doesn’t directly offer phone service although it can offer backhaul services to network carriers. You might be thinking of Inmarsat?
    1. Not keen on an ISP where my service can be randomly turned off if a billionaire decides they don’t like me, or want me blind when someone attacks me. I’ll stick to services operated by functioning adults instead of folks who have whole divisions dedicated to distracting them so they don’t meddle with actual engineers.
      1. “Not keen on an ISP where my service can be randomly turned off if a billionaire decides they don’t like me RoCkEt MaN bAd ReEeEe.”
        Grow up. You’re not nearly interesting enough for a billionaire to ever pretend to care about. Also if you think Musk is uniquely a billionaire douche majeure, you’re ignorance is really spilling over.
          1. Incorrect. The proper usage in this context is in fact “you’re,” aka “you are not nearly interesting enough for a billionaire to ever pretend to care about.” You’re.
          2. Incorrect. The appropriate word is applied in the context of the statement. “You’re,” as in, “you are not nearly interesting enough for a billionaire to even pretend to care about.” You’re.
            “Your” is a possessive adjective, indicating ownership or belonging.
            “You’re” is a contraction of “you are.”
        1. *your ignorance…
          You would know there was more than one possible correction if you bothered to reread your own post.
      2. I recently used the satellite SMS feature on an iPhone while in the mountains without service for a few days. I didn’t know it was an option. It just popped up asking if I wanted to connect to a satellite. It had a handy alignment feature showing the relative direction of the satellite I needed to point at. It just worked. I was amazed at how easy it was to use. It handled the handoff to another satellite well showing the next one coming over requiring me to turn towards it. I need to research what satellites they are using for this.
      3. The only other options will require you to sell a kidney to afford them and they will provide significantly worse service.
    2. Has the added benefit of being insanely cheaper compared to the type of satellite phone being talked about above. Has the huge disadvantage of not working in most regions of the globe, mostly defeating the point of a sat phone. Maybe someday
  3. Let’s not overlook the importance of basic voice communication.
    I know of at least one government agency (not FEMA) that wants satellite-based voice service for one primary reason – to at least have a chance at maintaining it’s mission in the event of the next event that overwhelms legacy PSTN and IP-based communications.
    This agency had important work to do when 9/11 happened, and for 3 days, struggled to do most of it.
    The availability of the called persons is of course subject to the same risks as a 9/11 type event, depending on what technology they use. But an Iridium-to-Iridium call (for example) should in theory have a greater possibility of success.
  4. ’round about y2k we had a sat phone (an Iridium, I think) that had a 9600 bps serial connection you could plug directly into your computer for data transport. $3/minute for satellite email.
    But that’s not so bad: 15 years earlier it was $3/minute for 300 bps VHF radiotelephone data. In 1985 we thought it was pretty neat to be doing wireless email forty miles from the nearest paved road.
  5. Iridium, on the other hand, operates 66 satellites
    Funny thing: Iridium was supposed to have 77 satellites, like it says on the tin — the atomic number of Iridium is 77. They didn’t change the name when they downsized to constellation to 66 though, because “Dysprosium” just doesn’t have the same ring to it.
      1. Not my quip: Credit goes to insider David Bell, who related that to me sometime late in the last century. Thanks David, wherever you are.
  6. We could have had this with Orbital Antenna Farms. Even larger than Bluewalker, big antenna farms mean smaller consumer devices without megaconstellations ruining the sky.
  7. As someone who regularly uses Irridium for work communication, I sure hope the rollout to smartphones has less failed calls.
    I suspect the average consumer will have much less tolerance than I will.
    1. Keep in mind that an Iridium sat takes about 10mins to go from horizon to horizon over any particular area (they are always orbiting) before hand-off. The tip of the antenna must have direct open line of sight to the sat during that time. IE: You could be standing still and have full signal, then have it drop if the sat moves behind a treeline. This is actually beneficial in certain scenarios; If you break a leg on the side of a mountain, you will eventually get signal. You will not with Inmarsat (geostationary) if facing the wrong way. Best advice is to go to the tallest spot possible with the least amount of obstructions possible.
  8. Before beginning road trips from a previous work site out in east Jesus, we were encouraged to reserve one of the site’s Iridium handsets in case we got stuck in the sticks. We’d always test ours before departing, but never needed to use it.
    Another workmate discovered the hard way that it wasn’t enough to have the handset. It behoved one to coordinate with one or more friends back in town so that if they saw the strange number pop up on their phone, they’d know to PICK UP, rather than hang up on an assumed spam call.
    1. one trick from the old ma-bell days was to not answer the call and to know that the call itself was the message and you knew what to do with out taking and paying for the call minutes.
