This Week In Security: Perplexity V Cloudflare, GreedyBear, And HashiCorp
The Internet is fighting over whether robots.txt applies to AI agents. It all started when Cloudflare published a blog post, detailing what the company was seeing from Perplexity crawlers. Of course, automated web crawling is part of how the modern Internet works, and almost immediately after the first web crawler was written, one managed to DoS (Denial of Service) a web site back in 1994. And the robots.txt file was first designed.
Make no mistake, robots.txt on its own is nothing more than a polite request for someone else on the Internet to not index your site. The more aggressive approach is to add rules to a Web Application Firewall (WAF) that detects and blocks a web crawler based on the user-agent string and source IP address. Cloudflare makes the case that Perplexity is not only intentionally ignoring robots.txt, but also actively disguising their webcrawling traffic by using IP addresses outside their normal range for these requests.
This isn’t the first time Perplexity has landed in hot water over their web scraping, AI learning endeavors. But Perplexity has published a blog post, explaining that this is different!
And there’s genuinely an interesting argument to be made,that robots.txt is aimed at indexing and AI training traffic, and that agentic AI requests are a different category. Put simply, perplexity bots ignore robots.txt when a live user asks them to. Is that bad behavior, or what we should expect? This question will have to be settled as AI agents become more common.
Breaking Into the Vault
Researchers at Cisco Talos took a look at the Dell ControlVault, a Hardware Security Module (HSM) built into many Dell laptops. The firmware running on these embedded processors had some problems, including a stack-overflow and other memory-related issues. Usually the potential for abuse of these kind of attacks is limited mostly to the theoretical realm, but this embedded HSM also includes accessible USB pins, that can be accessed with a custom connector. The vulnerabilities found, then represent a real attack scenario where the firmware on the HSM can be tampered with, via nothing more than physical access. To prove the point, the Talos write-up includes a great video of a compromised machine accepting a green onion as a valid fingerprint for Windows Login.
Trend Micro In the Wild
Trend Micro’s Apex One system is under active exploitation, as a pair of vulnerabilities allow an authenticated attacker to inject system commands in the system’s management console. The full fix is expected to roll out later this month, but a mitigation disables a specific feature of the console, the Remote Install Agent. This leads to the obvious conclusion that the installation process was allowing for code execution as part of the install process.
GreedyBear
There was an interesting malware campaign run this year, by a group that Koi Security is calling GreedyBear. The campaign could be called a blitz, where malicious browser extensions, ransomware binaries, and scammy websites were all employed at once, with the goal of stealing cryptocurrency. The surprising thing is that so far not much over $1 million has been reported as stolen through the campaign.
The first technique used was “Extension Hollowing”, where safe, boring browser extensions are published, and maintained for a few months. Good reviews come in naturally or are purchased, and the publisher appears trustworthy. Then the extension is updated, with malicious code suddenly shipping. These extensions are now sniffing for user input and form filled data.
The second technique used was the old classic, packing malware into cracked and pirated software. The source of many of these malicious binaries seems to be primarily Russian piracy sites.
The final approach discovered was the simple scam website, often typo-squatting on nearly-legitimate domain names. These sites advertised fake hardware wallets or wallet repair, but only existed to steal whatever information would-be customers were willing to share.
The question may be raised, why does Koi Security believe all this activity is connected? The answer boils down to a single IP address, 185.208.156.66. This was the Command and Control server for the entire network of activity, and should be seen as a definite red flag in logs and records.
HashiCorp Vault Audit
The fine folks at Cyata took a crack at HashiCorp’s Vault, a source available secrets storage solution. And they discovered a host of subtle but important issues. The first on the list is an outstanding find, and it deals with how Vault protects against brute-force attacks. It’s supposed to be a simple counter, that locks out password attempts for a while, once a threshold of failures has been reached. The problem is that usernames aren’t case sensitive, but the failure counter is case sensitive in tracking password failures. Tried guessing the admin password too many times? Try the Admin account next.
The Multi-Factor Authentication has some issues, like the TOTP code reuse protection. This attempts to enforce that a code is only used once while valid. The problem is that a code of “ 123456” and “123456” both evaluate the same for the TOTP valuation itself, but as different codes for the reuse protection. This could enable an attacker to first abuse the reuse protection error message to identify a valid but used code, and then insert the space to be able to use the code for authentication.
After authentication, this same style of attack is possible again, this time targeting the root policy protections. An admin cannot assign this “root” policy, but can assign a “ root” policy. Those are treated as different policy identifiers by the validation code, but the same thing in the final implementation.
And finally, they discovered a Remote Code Execution flaw, via plugin installation. This one requires admin access, but an information leak and an audit log that allows writing to anywhere on the disk is enough to execute code injected in that audit log. This seems to be the first RCE ever made public in Vault, which is an impressive statement for both Hashicorp and Cyata.
Bits and Bytes
Nvidia isn’t taking last week’s talk of backdoors laying down, taking the offensive this week to reassure everyone that “There are no back doors in NVIDIA chips.” There’s a separate bit of news that US lawmakers are considering legislation that would require a kill-switch and location verification in future hardware.
It’s reassuring to be reminded that cyber-criminals do get captured and extradited. A Nigerian man was arrested in France and is being extradited to the US on multiple charges of fraud, identity theft, and other crimes. No word on whether the Nigerian national was or has claimed to be a prince.
And finally, filed in the “awkward” category, Google has disclosed that they were also a victim in the Salesforce hacks that Google researchers discovered and first publicized. These were good-old social engineering campaigns, where the attacker contacted an employee at the target company, and convinces them to read off an eight-digit security code. A group calling itself ShinyHunters has started an exploitation campaign using data pilfered in the attacks.
7 thoughts on “This Week In Security: Perplexity V Cloudflare, GreedyBear, And HashiCorp
  1. Any robot, AI, corporeal or non corporeal being should respect robots.txt. But I put a lock on my door, that doesn’t mean everyone will respect that and keep out but if I find my stuff in someone else’s house I’ll be calling the authorities all the same. So does that mean I can trawl each AI to see if they’ve got my info or maybe by trawling for that info I’m giving it to them anyway?
    1. I run multiple public facing websites for a large corporation. The bots are hostile.
      I don’t have a problem with a bot archiving the content of our sites, they can make a copy of the public facing portion by consuming the site xml file and fetching the content without pounding the site in ridiculous ways.
      The AI bots get lost trying to “browse” the site, they are often quite stupid and don’t interact all that similarly to a human. We have a complex search they tend to get confused by and then, before they leave, somebody else will trigger another bot to do the same thing. We end up with a not insignificant number of bots using the most resource intensive process and getting functionally lost and confused.
      It’s one thing to decide you need more server capacity because of actual users, but to be pushed because some of the bots are overly aggressive, don’t cache properly and otherwise treat the browsing experience as outright hostile. No thanks.
      Web Access Firewalls are a solution to that problem. And I’ve been known to get rather aggressive when I see bad behavior.
    2. I am a corporeal being and I don’t pay any attention to robots.txt. I neither explicitly honor it nor explicitly try to get around it. My web browser might pay attention to it, but as a corporeal being, I do not.
  2. A splendid post! Up to the very last sentence. Dalton goin’ all cyber Roadhouse on the bad guys. Remember that episode of Seinfeld where Elaine said “He took it out”? Just do your job and go with Christ brah.
  3. “Put simply, perplexity bots ignore robots.txt when a live user asks them to. Is that bad behavior”
    Yes. 100%. Does anyone actually think they’re not using user interactions for future training sets? Or that if this was okay, some jerk isn’t going to say “please crawl these sites for me and add to a new training set.” It’s okay, our bot didn’t crawl for those pages, we just asked it to. Huh?
    It’s complete garbage. I’m amazed at how rapidly people defend plagiarism machines.
