Running Code On A PAX Credit Card Payment Machine
The PAX D177 PoS terminal helpfully tells you which tamper points got triggered. (Credit: Lucas Teske)
These days Points of Sale (PoS) usually include a digital payment terminal of some description, some of which are positively small, such as the Mini PoS terminals that PAX sells. Of course, since it has a CPU and a screen it must be hacked to run something else, and maybe discover something fun about the hardware in the process. Thus [Lucas Tuske] set out to do exactly this with a PAX D177 PoS, starting with purchasing three units: one to tear apart, one to bypass tamper protections on and one to keep as intact reference.
As expected, there are a few tamper protections in place, starting with pads that detect when the back cover is removed and a PCB that’s densely covered in fine traces to prevent sneaky drilling. Although tripping the tamper protections does not seem to affect the contents of the Flash, the firmware is signed. Furthermore the secrets like keys that are stored in NVRAM are purged, rendering the device effectively useless to any attacker.
The SoC that forms the brains of the whole operations is the relatively obscure MH1903, which is made by MegaHunt and comes in a dizzying number of variants that are found in applications like these PoS terminals. Fortunately the same SoC is also found on a development board with the AIR105 MCU that turns out to feature the same MH1903 core. These are ARM Cortex-M3 cores, which makes targeting them somewhat easier.
Rather than try to break the secure boot of the existing SoC, [Lucas] opted to replace the SoC package with a brand new one, which was its own adventure. Although one could say that this is cheating, it made getting a PoC of custom code running on one of these devices significantly easier. In a foll0w-up article [Lucas] expects to have Doom running on this device before long.
8 thoughts on “Running Code On A PAX Credit Card Payment Machine
  1. Most secure POS systems are using some form of ARM vortex M3 core. Some of them have two one more secure ( keyboard entry pin, encryption etc., and a less secure chip For OS – comms, printing etc.
    1. I think that “hack” is just to have them registered to another business, yeah?
      not much use in hacking it to use someone else’s receiving account as you couldn’t retrieve the funds, nor is there any use in having the keys for the payment processors replaced with something else.
      or are you saying they use them for private “club cards” instead of say poker chips? that seems like a pretty wild way to solve that “problem”
  2. Interesting, i’m actually tampering with one to run small Nokia Bounce, tetris or Doom on it but it seems the firmware is hard to crack, swapping the MCU would be an option if i had a blowing solder machine, i hope he’ll get into it so i can have a baseline to work on
Leave a Reply to kovoCancel reply
