An Audio Brick For Your Smart Home
If you’ve ever wanted to pump sound to all the rooms of your house, you might use any one of a number of commercial solutions. Or, you could go the more DIY route and whip up something like the Esparagus Audio Brick built by [Andriy].
The concept is simple—it’s a small unit, roughly the size of a brick, which streams high-quality audio. It’s based around an ESP32, which pulls in digital audio over Wi-Fi or Ethernet. The microcontroller is hooked up to a TAS5825M DAC, which comes with a built-in amplifier for convenience. The Esparagus is designed for integration with Home Assistant, allowing for easy control as part of a smart home setup. It’s also compatible with Spotify Connect, AirPlay, and Snapcast—the latter of which provides excellent sync when using multiple units across several rooms.
Design files are available on Github for the curious. We’ve seen other neat projects in this space, before, too—like the charmingly-named OtterCast. Video after the break.
38 thoughts on “An Audio Brick For Your Smart Home
    1. Why local storage? The stated intent is “in every rooms”, so you would have several of these bricks. It makes more sense to store your music on a NAS (even if this is just a Raspberry Pi zero W with a large capacity SD card) and share across all bricks. At worse, this is a software issue.
      1. I did just that, I have four pi zeros, each with a dac card, as a multi room system playing music stored on my NAS. I have them all synchronized but they could play different tracks if wanted. I have existing hifi’s so these just plug in to the aux ports. It used mpd and snapserver on my NAS and snapclient on the pi’s
        1. Mood player is a complete ready made for rpi zero 2 w if you add a dac card with spdif out for the amplifier. Local storage and file sharing is included software.
          Rpi 3 or higher for master device.
    1. Much like I would not care to own or need knitting needles, as some of us do not do “knitting”, you do not need this particular bit of kit? No?
      Why ask for features that are clearly outside the scope of a given peoject?
    2. Even if it did have onboard storage, having to select which songs to play out of thousands on that user interface is going to defeat the point.
      You need the Home Assistant, so you can connect your phone to it and actually control it. If so, you can just as well play music stored on your phone, or from a networked hard drive, or from a cloud storage site. There’s no need for local storage in the device because it is supposed to be a networked device.
    3. Well then, this is not for you. As you look around and explore the world, you may find much of it is in that category. You are not the only person, and many things are for other people.
  1. Kinda unrelated but
    You can buy 1$ boards which have an sd card slot, bluetooth, usb connector to accept thumb drives to play audio from. A speaker output plus a 3.5mm jack as well. Just power them using the micro USB port and they work well for years without any supervision
      1. I tell the voices in my head to play stuff at random. I have a whole orchestra sometimes!
        It’s the only place I can hear Steven Caudel’s “Wine Dark Sea”.
        Or Caravan…
  2. This comment section is abysmal. Who cares if it doesn’t have onboard storage?
    The creator clearly had a goal in mind and then took the time to learn and build something fit for purpose. This is prime hackaday material, and I love the end product.
    F the haters
    1. Honestly, seems a bit pissy both ways.
      On one hand, the OP built things the way he wants it, but shared his files. Be happy.
      On the other hand this is HAD, a place where readers routinely discuss “enhancements” to existing projects/products. So chill.
      Might as well go for a soda.
      1. Yeah many comments are giving off big Comic Book Guy energy. If dude wanted such and such stuff in the project, it’d be there.
        Likewise, it’s weird for people to react to the suggestions like they are antiquated or redundant… The project itself is a neat and elegantly executed bespoke solution to a problem that most people just solve with Bluetooth or by logging their smart speakers in to an Amazon or Google account.
        Dunno how much this project would call for it, but SD readers make flashing updates or testing alternate configurations pretty easy, all things considered. But it wasn’t part of the project, and that’s okay too because it’s pretty cool.
    2. Agreed, this section is abysmal. Disagree that there are any haters. Gen Z has clearly entered the chat.
      SD would be great functionality to add, and that’s a fair point. The designer didn’t see fit to add it in, that’s fair too. He made the design open so that one could add it if they wanted to. That’s about as fair as it gets. If someone wants it that badly, they can add it themselves. I fail to see where anyone is being a “hater.” What a lazy term…
      It’s HAD… welcome to it. Here’s some thicker skin for you. Wild that some folks can get so rattled over an SD card, good grief.
  3. yep, fair to add it or not – but why I made that comment (SD card) is the board is so good in everything it DOES have but a little bit more would have made it much much more versatile. And no, it wouldn’t need a more complicated display, as you could manage via wifi/bluetooth.
  4. PoE support would improve this project.
    The point of this project is to have multiple devices work together.
    SD card to pay music is limiting per device.
    Updates via SD card would take much more effort than programing directly to the ESP32.
    Suggestions for SD card support on a streaming device is like wanting Bluetooth on your microwave oven. Sure you could but why?
  5. Anyone know something low-fi and cheaper? Was just trying to get audio messages around the house for security, linked to events controlled by home assistant or smart things. If it stored 10 or so clips of ~10 seconds at low nitrate, ideal.
  6. Hey Folks.
    I’m the person behind this project, and first of all, I don’t mind hearing suggestions from community folks, however inappropriate they may seem (in a project suggestion sense, you know).
    I considered SD-CARD and decided not to go with it. It is not supported neither by HA (which is my main use case), nor squeezelite; it requires few pins that I don’t have (Although I might go with S3, which would solve that); and I want to make it affordable, believe me I spent lots of time shaving every cent. SD-CARD is a gold-plated part in my stadards, so you know… Besides, I have another project coming up that is portable and SD-CARD driven: https://hackaday.io/project/203979-loud-esp-rfid-edition.
    As for PoE, sounds like a reasonable suggestion, but it this point in the ideas box as well, because of the price. I’m looking into that for maybe “PoE version”, but charging every board extra $10-15, even when not used seems to be a bad way to do it.
    1. Some SBCs provide a header that connects to the isolation transformer’s center taps (IIRC) and then a PoE add-on is a separate purchase which takes that header and provides DC back for the board.
      I’m one of those prospective customers who’d be interested in a PoE version, but I wouldn’t mind paying slightly more for the add-on. Then you can sell (or just provide docs) for the add-on without raising the base cost as much. No worries if it doesn’t make sense to develop that. Maybe it’s viable to use the same pin layout as an existing module?
Leave a Reply to joshgrobanholidaytvspecialCancel reply
