Building A Smart Speaker Outside The Corporate Cloud
If you’re not worried about corporate surveillance bots scraping your shopping list and manipulating you through marketing, you can buy any number of off-the-shelf smart speakers for your home. Alternatively, you can roll your own like [arpy8] did, and keep your life a little more private.
The build is based around an ESP32 microcontroller. It connects to the ‘net via its inbuilt Wi-Fi connection, and listens out for your voice with an INMP441 omnidirectional microphone module. The audio data is trucked off to a backend server running a Whisper speech-to-text model. The text is then passed to Google’s Gemini 2.5 Flash large language model. The response generated is passed to the Piper Neural Voice text-to-speech engine, sent back to the ESP32, and spat out via the device’s DAC output and a speaker attached to an LM386 amplifier. Basically, anything you could ask Gemini, you can do with this device.
By virtue of using a commercial large language model, it’s not perfectly private by any means. Still, it’s at least a little farther removed than using a smart speaker that’s directly logged in to your Amazon/Google/Hulu/Beanstikk account. Files are on Github for those eager to dive into the code. We’ve seen some other fun builds along these lines before, too. Video after the break.
15 thoughts on “Building A Smart Speaker Outside The Corporate Cloud
    1. I thought ‘well Gemini 2.5 can be a locally run model, it’s not too hard to do this on ollama with the model from hugging space’ so looked at the code… and sadly in the code https://github.com/arpy8/ESP32_Voice_Assistant/blob/main/server/main.py
      from google import genai
      llm_client = genai.Client()
      So, yep, they may as well have just bought a google device as the spyvertising company is getting absolutely everything, and training on it.
      1. Right, the actual LLM models require hundreds of GB of vRAM to run at any appreciable performance level … and they are largely closed source.
        IIRC Meta’s llama or whatever they call it has small enough models to run on a local machine, and they’re Open-enough too
        1. There are plenty of models that can be ran locally. The “open sourced” Gemini models are called Gemma. Gemma3 comes in 5 sizes, from 292MB (270m param) to 17GB (27b param). These can be ran local, the smaller models on less capable hardware.
          gpt-oss (20b param) will fit in a 16GB GPU and give 70+ tokens a second (on a Radeon RX 6800XT). I can run the 120b param gpt-oss on in 128GB of RAM (two year old Ryzen 7950x CPU powered) and get 8+ tokens a second.
          Sure, there are some 300-500+b param models you can run that take 4 GB200s (total 512GB vRAM). But there are distilled versions of the large models are very capable and are more accessible than people think.
          Install ollama and see what performance you get: https://ollama.com/library/gemma3
          Example: “ollama pull gemma3:4b” then “ollama run –verbose gemma3:4b”
    1. You always need to be aware of security, yep. Dead right and you make an important point.
      The safest ‘commercial grade’ solution that avoids relying on a computers firewall is to put IOT and untrusted devices on a seperate VLAN in our routers. So that such untrusted devices are quite safely seperate from the rest of the network at OSI level 2 and any harm is limited to only other IOT devices on that partitioned network only.
      I have quite a number set up, some VLANS have no internet access in or out, some only have out, some are bidirectional, then there is another vlan on top for dangerous devices with heaters like my 3D printer. Finally a vlan dedicated for secure devices and a guest vlan. Some have their own access points and some must be hard wired to access.
  1. I actually made a fully local voice assistant using my RTX3060 12GB VRAM GPU, running a 7B LLM model, a text-to-speech model, and a speech to text model.
    The round trip time was ~8s, but depended on the length of the speech. Text to speech and speech to text the most amount of time, I couldn’t get text-to-speech working with GPU support (not enough VRAM)
    It can be done. It was pretty fun to talk to it for about 10 minutes, then it got boring
Leave a Reply to MakeCancel reply
