A Deep Dive Into Inductors
A graph of current versus time for circuits with and without inductors
[Prof MAD] runs us through The Hidden Power of Inductors — Why Coils Resist Change.
The less often used of the passive components, the humble and mysterious inductor is the subject of this video. The essence of inductance is a conductor’s tendency to resist changes in current. When the current is steady it is invisible, but when current changes an inductor pushes back. The good old waterwheel analogy is given to explain what an inductor’s effect is like.
There are three things to notice about the effect of an inductor: increases in current are delayed, decreases in current are delayed, and when there is no change in current there is no noticeable effect. The inductor doesn’t resist current flow, but it does resist changes in current flow. This resistive effect only occurs when current is changing, and it is known as “inductive reactance”.
After explaining an inductor’s behavior the video digs into how a typical inductor coil actually achieves this. The basic idea is that the inductor stores energy in a magnetic field, and it takes some time to charge up or discharge this field, accounting for the delay in current that is seen.
There’s a warning about high voltages which can be seen when power to an inductor is suddenly cut off. Typically a circuit will include snubber circuits or flyback diodes to help manage such effects which can otherwise damage components or lead to electric shock.
[Prof MAD] spends the rest of the video with some math that explains how voltage across an inductor is proportional to the rate of change of current over time (the first derivative of current against time). The inductance can then be defined as a constant of proportionality (L). This is the voltage that appears across a coil when current changes by 1 ampere per second, opposing the change. The unit is the volt-second-per-ampere (VsA-1) which is known as the Henry, named in honor of the American physicist Joseph Henry.
Inductance can sometimes be put to good use in circuits, but just as often it is unwanted parasitic induction whose effects need to be mitigated, for more info see: Inductance In PCB Layout: The Good, The Bad, And The Fugly.
5 thoughts on “A Deep Dive Into Inductors
  1. I have so many projects that need a custom transformer but i just never get around to it
    I also have EE cores and their bobbins lying around but no patience to start winding. Also litz wire is so expensive!
    1. I also did a deep dive on inductors awhile back. I wrote some inductance tools to help people design inductors optimized for specific purposes.
      The typical inductance formula is only accurate to about 100 kHz, and only tells you what the inductance would be, and not (for example) the quality factor.
      My tools allow you to optimize specific features of the coil. Usually you want to optimize the Q-factor, but you could also optimize the conductor length or transition frequency.
      https://hackaday.io/project/193000-inductance-design-tools
Leave a Reply to shinsukkeCancel reply
