Making Big Dry Ice Blocks With Low Pressure CO2
Although the term ‘dry ice’ is generally used for solid CO2, it’s much more accurate to call this ‘dry snow’, as, rather than being actual solid blocks, they are effectively snow that’s been compressed really tightly. While not really necessary for most applications of dry ice, it is possible to make blocks of actual CO2 ice, and thus [Hyperspace Pirate], as someone with a healthy obsession with cold things had to make some of his own.
Continue reading “Making Big Dry Ice Blocks With Low Pressure CO2” →
The clutch-purse cyberdeck, complete with pearls for the chain.
Mermaid Clutch-Purse Cyberdeck Is Unappologetically Girly
We feature a lot of DIY portable computers — rehash the “is that a cyberdeck” in the comments to your heart’s content — but how many of them are explicitly girly? Certainly, none of the ones that come to mind oozed the distilled femme energy of [cc] AKA [bossbratox]’s project, playfully titled “Mermaid in the Shell”.
The build started with a frame clutch purse, which, given that it comes with nice hinges and latches, is really a brilliant starting point for a project case. The fact that you can find them shaped like pink seashells really seals the deal for this particular project. A ZitaoTech BB Q10 keyboard — in white, naturally — pairs with a 3.5″ touchscreen as the interface for a Raspberry Pi 3A+. You might be thinking, “great, another toy with an old Pi inside. What can you really do with a Pi3 in 2026?” Well, admittedly, for full-fat desktop Linux, the 3A+ is looking a bit long in the tooth and short in the RAM.
Continue reading “Mermaid Clutch-Purse Cyberdeck Is Unappologetically Girly” →
