One of the worst moments almost every hacker has experienced is a hard drive inexplicably dieing. And of course, its at the most inopportune time and you’ve had no chance to backup!
Recently there has been an influx of Seagate hard drives (specifically the 2700.11s) kicking the bucket with firmware errors 0LBA and BSY. The good news is [Gradius2] has made guides to unbrick your drive without having to match serials.
The procedure is lengthy, complicated, can easily become expensive, and there is the possibility of losing your data so it’s not recommended if you’re only getting those pictures of Mr.Fluffykins back. In such a case, Thermite might be a bit better solution.
[Thanks Calvin]
