Bicycle Heads Down Display Shows You The Way
On a bicycle you’re typically looking ahead and slightly down to make sure you don’t ride over any potholes. While a speedometer is great on the handlebars, what if you could project your speed and other information onto the road ahead? Well, it turns out if you have a smartphone and a bit of ingenuity, you can do just that!
We’ve seen this hack done before with a pico projector, but that’s a pretty big investment for your bicycle. So [Peter] had another idea. What if you could just use your cellphone as is and a bit of optics? It turns out you can buy some pretty cheap “cell phone projectors” from China or Amazon — it’s basically a little cardboard box that your phone fits into, with a cheap plastic lens to project your image. Lumen output is pretty miserable, but if you’re riding at night, it is enough to see by!
Continue reading “Bicycle Heads Down Display Shows You The Way”
