The 2016 Hackaday SuperConference took place last month in sunny Pasadena, California. Also calling Pasadena home is the Jet Propulsion Laboratory, the place where Mars rovers are built, where probes are guided around the solar system, and where awesome space stuff happens.
JPL had a large contingent at the SuperCon and two of them teamed up to present their talk: Charles Dandino and Lucy Du. Lucy is a mechatronics engineer at JPL and already has a little bit of fame from fielding a Battlebot in the last two seasons of ABC’s series. Charles is also in mechatronics, with experience with Curiosity, the Mars 2020 rover, and the (hopefully) upcoming asteroid redirect mission.
In their talk, Charles and Lucy uncovered some of the hacks happening in the background at JPL. There’s a lot of them, and their impact goes much further than you would expect. Everything from remote control cars to keeping spacecraft alive on the other side of the solar system.
