If you have a signal that passes through a capacitor or transformer, you will lose the DC portion of the signal. What do you do? If you need it, you can restore the DC bias using various techniques, as [Sam Ben-Yaakov] shows in a recent video.
These types of circuits were common in analog TVs, and, in fact, [Sam] shows the schematic of a TV to explain the need for the DC level. In that case, a vacuum tube diode does the work, but a solid state one will do the same job.
