Conductive ink or paint is lots of fun. It opens up tons of possibilities for flexible and unique circuits — unfortunately, it’s pretty expensive. [Brian McEvoy] shows us how to make your own for cheap, and it works great!
He started trying to formulate his own recipe after playing with other Instructable guides and commercially available paint, and what he found is it’s really not that complex! Graphite powder, acrylic paint, and a jar with an airtight seal — seriously, it’s that simple! But, like any engineer worth their salt (he calls himself the 24 Hour Engineer), he had to do some tests to compare his formula.
In a detailed experiment he compares his formula to the commercially available Wire Glue, and two other recipes using Elmer’s Glue-All and graphite, and Titebond III with graphite. The results? Acrylic paint and graphite produce the most conductive material — and the cheapest!
Now that you can make conductive ink, why not 3D print a circuit stamp to make your very own SMD circuit board!
