If you’re looking to add a bit of the future to your living room, you might want to look at this tutorial to build a very professional infinity mirror table.
It’s an IKEA RAMVIK coffee table, modified to include RGB LEDs and a one-way mirror for that ever-so-awesome infinity effect. And technically, you only have to cut one hole in the table.
By placing a large mirror underneath the glass, wrapping the inner edge with a strip of RGB LEDs and coating the original glass top with a reflective car tint, it’s a pretty simple hack that results in a very polished product — not something that can be said for most of our projects! But to make it even better, [Pierre] added an NFC chip under the table, allowing you to control the color with just a tap.
Continue reading “Impressive NFC Controlled Infinity Mirror Table Cuts No Corners”
