As with Jabba the Hutt we’d like to have our own service droid to serve up a cold one. We’re in luck; it looks like you can make your very own beverage dispensing droid if you don’t mind a little awkward dispensation.
The body started as one of those big protein drink mix containers. After spraying it white and masking off the entire thing with blue painter’s tape, the shapes for the blue designs were cut out and painted. Half of a foam sphere from the hobby shop was used to form the dome.
Liquids are dispensed by the pump system from a Super Soaker motorized water gun. You can see it fill up a beaker with a mysterious blue liquid in the video after the break. It’s a long way from challenging the Bar2D2, but it’s also something a mere mortal can build
Continue reading “R2D2 Drink Dispenser Will Happily Tinkle In Your Glass”
