We aren’t sure there’s enough information in the [We Make Machines’] video to easily copy their self-balancing bike project, but if you want to do something similar, you can learn a lot from watching the video. Building sufficient gyros to keep the bike stable required quite a bit of trial and error.
There are some tricks to getting a stable heavy weight to rotate without a lot of vibration and problems. The gyros go on the rider’s saddle, so you aren’t going to be able to ride in the normal fashion. However, a substantial motor drives the wheels so there’s no need to pedal.
The first attempt to self-balance stayed stable for about 10 seconds. Some of it was fine-tuning code, but noise from the gyros also threw off the angle sensor. A higher-quality sensor seemed promising, but it didn’t really fix the problem. Instead of using PID, the guys tried an LQR (Linear Quadratic Regulator) algorithm. Once that was sorted and a servo allowed for steering, it was time to let the bike roam free.
Continue reading “A Self Balancing Bike For Crash Dummy Billy”
