We had some interesting High Voltage posts over the past couple of weeks. Today we are announcing the next theme: Engine Hacks. Each day for the next two weeks we will be doing a new post about some sort of interesting engine project. We’ll be showing projects where engines are built from scratch, engines are modified to work in a new way, or where an engine is used in an manner that it wasn’t originally intended. If you or someone you know has an interesting project that you think might fit well within this category, please let us know through our tip line.
Pictured above is an EVIC (Electronic Valve Internal Combustion) engine. This type of engine doesn’t have a cam shaft to actuate the valves. Solenoids are used instead and are paired with a small processor and some sensors to determine when and how long to open the valves. This type of engine allows you to do things like vary the amount of fuel coming into the cylinder on a continually variable basis. If you paired this with electronic ignition, you could even make the engine run in reverse!
