m8ta fun did an extensive teardown of OCZ’s Neural Impulse Actuator (NIA). OCZ’s computer/mind interface is actually a fairly straight forward design. An analog front-end cleans and amplifies the ‘neural’ signal with a few op-amps before feeding it to a 24 bit analog to digital converter (ADC). A USB enabled PIC microcontroller reads the 24bit parallel ADC output through a common 7400 series parallel to serial adapter IC. The device has an ICSP programing header (top right), though it’s not yet clear if the PIC can be read or written.
[Thanks, joeyo]
