This Week In Security: Record Patch Tuesday, PHP’s Bad Time, The Oldest Vuln, AI Armies, And More
It’s no longer a proper month without Microsoft breaking its own record for security fixes, and October’s Patch Tuesday was no exception. Brian Krebs brings the roundup: more than 1,400 vulnerabilities fixed in a single batch, dwarfing September’s record of nearly 1,000, which itself was about ten times the normal monthly load. According to Tenable, Microsoft has now passed 4,000 CVEs for the year with two months still to go.
Only one of the fixes is for a vulnerability already being exploited in the wild: CVE-2026-96951, a security feature bypass in the Windows Shell affecting Windows 10, 11, and some Server versions. A .NET Framework bypass, CVE-2026-108398, was publicly disclosed before the patch, giving attackers a head start, and with modern AI tooling, it seems like not much of a head start is needed. At least 78 of the bugs are rated critical, and most of those allow remote code execution with little or no user interaction. Windows 10 holdouts can relax a little: Microsoft quietly extended free updates through October 2027.  Given the pace of exploitation, this is probably the only way to prevent an Internet-scale meltdown.
Microsoft credits LLM-driven bug hunting for the volume, which leaves the poor admins who have to test and deploy all of this in an unenviable spot. Fortra’s analysis shows that only 26 Microsoft vulnerabilities have landed in the CISA KEV catalog of actively exploited bugs so far this year, so start there. For the rest, the SANS Internet Storm Center and Cisco Talos have the usual breakdowns by severity. Or, you know, just patch everything and hope for the best, which is roughly what everyone does anyhow.
Continue reading “This Week In Security: Record Patch Tuesday, PHP’s Bad Time, The Oldest Vuln, AI Armies, And More” →
This Week In Security: Flock Cameras Are Old, Microsoft Patches Patches, And Researchers Attack SSH
Leak site Distributed Denial of Secrets has released a dump of the filesystems of a Flock camera, and Micah Lee has published a dive into the contents.  Apparently the Flock security model did not include “angry citizens with a hacksaw in the middle of the night” in the physical security category.
The first thing Micah notes is that the Flock hardware runs Android 8.1 (for those not keeping track, the current Android release is Android 17 released in June 2026).  The version of Android running on the Flock camera was last patched in June of 2018, and the Linux kernel (3.18.71) is over nine years out of date, and the 3.18 series went end-of-life in 2019.
You might assume “wouldn’t an operating system this old have known vulnerabilities?”, and you’d be completely right.  Micah calls out two in particular, one in the Qualcomm GPU which allows any program to manipulate kernel memory and gain root (similar, yet simpler, than the spate of kernel vulnerabilities this year that allowed manipulating memory via the disk IO cache), and the “WrongZone” vulnerability which allows a process to escalate to root via socket handling errors.  You might also guess both of these have been patched, and again, you’d be right, in 2021 and 2018 respectively.
Digging deeper, Micah discovers that API keys with access into the Flock infrastructure appear to be hard-coded into the binaries.  Each camera appears to request credentials from an authentication server, using the MAC address of the camera.  After obtaining the credentials from an Okta Auth0 sign-in service, the Flock stores them, in plain text.
Also stored on the camera unencrypted are logs and position data:  The camera dumped to Distributed Denial of Secrets came from a suburb of Milwaukee. Continue reading “This Week In Security: Flock Cameras Are Old, Microsoft Patches Patches, And Researchers Attack SSH” →
This Week In Security: It’s Patch Tuesday Again, TVs Spying, Supply Chain Worms Return, Prolonged Hack Impacts, Stolen IDs
Several times this summer, Microsoft’s Patch Tuesday, the monthly roundup of major security patches for Microsoft products, has included record-breaking numbers of security fixes. The August 2026 patch set actually seemed to catch up. Was this a sign of the bug apocalypse lessening? Ha, nope!
Brian Krebs at Krebs On Security once again brings his excellent roundup of Patch Tuesday events, with this months patch set absolutely crushing previous numbers with nearly 1,000 security fixes.
Two of the fixes are for zero-day vulnerabilities under active exploitation in the wild, both allowing privilege escalation on Windows. Privilege escalation bugs turn general vulnerabilities in applications and games into full administrator access to gain persistence and deploy ransomware, and generally make any vulnerability significantly worse.
Krebs also calls out a CVSS 9.8 (so close to a perfect 10!) vulnerability that allows remote code execution in the Windows shell with no user interaction and no authentication, a remotely exploitable DNS bug present since Windows Server 2012 and Windows 10 which will likely see exploitation in the wild soon, and over a hundred other bugs are ranked “Critical”.
How the sheer volume of vulnerabilities in this patch will fit with recent Microsoft recommendations that companies should apply the patches immediately remains to be seen. (Likely: not very well, depending on what new behavior and issues the fixes cause!)
Is Your LG TV Spying on You?
Gamers Nexus continues their trend of high-quality investigation, and they have posted another tremendous multi-hour investigatory video. This time Gamers Nexus focuses on the ecosystem of LG televisions and monitors.
It shouldn’t likely surprise many here that “smart” devices are usually more to the benefit of advertisers than consumers. Similarly, it shouldn’t be a surprise that a “smart” device harvests user data to sell to advertises. What may be surprising is the degree to which LG devices appear to collect data, how much data is sent even when collection is turned off, and how overt executives at the company are, with multiple executives making statements in pitches to advertisers that LG “owns the glass”, “owns the living room”, and is designed to correlate devices, inhabitants of the environment, and viewing habits so that ads can be served to the TV and mobile devices in the same room simultaneously.
With tracking enabled, the smart TV captures telemetry of what applications are used, as well as continually capturing the video displayed and reporting fingerprints to LG servers and ad partners. The screen content is tracked not only for TV, but for the HDMI inputs, including if the TV is used as a PC monitor. If voice control is enabled, the TV also records audio and analyzes it. The TV also continually scans the local network and nearby Wi-Fi networks, reporting all the devices it finds on the local network, including host name, MAC address, and sometimes software running depending on the MDNS advertisements. Near-by Wi-Fi networks are sufficient for very precise geolocation, so LG effectively knows the location of every customer, as well.
Continue reading “This Week In Security: It’s Patch Tuesday Again, TVs Spying, Supply Chain Worms Return, Prolonged Hack Impacts, Stolen IDs” →
This Week In Security: What’s In A Name, The AI Bugpocalypse Hits Everyone, OpenWRT Flaws, And Duress Passwords
The great thing about standards is there’s so many to pick from, right?. (Insert obligatory XKCD #927 here.) Several companies have developed naming schemes to refer to groups of attacks, and now Google has too.
Sometimes, malware, ransomware, or exploit groups name themselves: “Shinyhunters”, “LapSus$”, “Cl0p”, “Lockbit”, and so on. For the groups that don’t advertise their presence, identification and naming can be more difficult. Mostly state-run affairs that didn’t want to draw attention to themselves, these Advanced Persistent Threats (APT) groups were originally simply given numbers. APT28 refers to the Russian GRU Intelligence Directorate suspected of hacking the Democratic Party email servers, APT38 is a North Korean governmental agency involved in financial and crypto currency theft.
Multiple companies and agencies have developed naming schemes to make referring to threat groups easier, typically including a regional identifier as well. CrowdStrike naming uses name groups like “Bear” group for suspected Russian actors, “Panda” for China, “Spider” for unattributed crime groups, while Microsoft uses “Blizzard”, “Typhoon”, and “Tempest”.
Google, deciding there weren’t enough classifications already, now introduces “RELIC”, “CASTLE”, and “COMET”. Of course, each naming organization has dozens of other classification groups as well, but now the next time you hear about an attack being attributed to “Scattered Spider” you know it’s the CrowdStrike name for a crime group.
Critical OpenWRT DHCP Flaw Fixed
The Hacker News reports on a major release of OpenWRT which includes fixes to the odhcpd server, the embedded DHCPv4 and DHCPv6 server written by OpenWRT.
The bug is a straight-forward stack style attack where a buffer is allocated, but not length-checked against the data required to reply to a malformed request. OpenWRT runs on a wide range of devices, but one of the most popular legacy platforms still in use, the MIPS processor architecture, lacks most modern security protections against stack-based attacks, making this attack sting more than it might on other architectures.
The latest OpenWRT releases also fix issues in the uhttpd embedded web server, multiple issues in the LUCI web configuration interface that allowed attackers to inject cross-site scripting content and Linux kernel security fixes. If you run a direct OpenWRT build on your equipment, update! These bugs will have an extremely long tail however, with tens of thousands, or likely more, OpenWRT-based devices that will never see updates.
The company behind several of the findings, Hacker House, say they used multiple AI tools and both open and frontier models to discover the bugs, then manual review and testing to confirm before reporting.
Cisco to Stop Assigning (some) CVEs
Cisco has announced it is moving to a twice-monthly patch cycle. Additionally, Cisco will no longer assign CVEs to each bug in the release.
Cisco says this is in reaction to the rapid increase in bugs found by AI tools, and that “Assessing security risk CVE-by-CVE and applying point mitigations is no longer fit for purpose.” Cisco will still assign a CVE to a bug that “requires compensating controls” or is known to be exploited.
It seems like it will be business as usual for the most severe bugs, but it will be interesting to see what happens when exploits are found for bugs which did not get a CVE in a prior release.
Microsoft Suggests Three-Day Patch Race
Microsoft is now recommending a 3 day patch window for new patches. This is, to say the least, an “aggressive” schedule for applying new patches, given the recent track record of issues introduced by patches.
A update that crashes is inconvenient on a home computer — even more so if it’s your parent’s computer — but could be catastrophic when it brings down an entire corporate fleet. Most large organizations have their own internal patch schedules and internal testing requirements before patches are deployed, delaying the patch process further.
Systems like the CISA KEV database, a list of vulnerabilities known to be actively exploited, are in place to help identify the most important issues. With repeated record-breaking numbers of vulnerabilities pushed in Patch Tuesday and the decreasing support of the KEV and related vulnerability indexing systems, the load on IT departments and administrators is becoming impossible.
The AI “bugpocalypse” is finding record numbers of vulnerabilities, while also closing the timeline between bug to exploit to hours in some cases. The time between bug and exploit then drives the patch cycle, which means less testing. With less testing, the patches are less stable, leading to less trust in rapidly installing them.
Oracle Patches Almost 1500 CVEs
Moving directly from the impacts of the flood of Microsoft security issues, the July 2026 patch set from Oracle included fixes for 1499 security issues and 1434 CVEs over 334 Oracle products.
Oracle is also pressuring administrators to move to a monthly patch cycle, but acknowledges “transitioning to a monthly security patching cadence may require updates to existing operational processes”. Not to worry – there is a Oracle consulting service you can hire to help you patch your Oracle problems.
Linux Patches 323 CVEs in Two Days
After announcing over 400 CVEs in the Linux kernel last week, Linux mainters have announced an additional 323 in the last three days alone. The vulnerabilities cover Bluetooth, Ethernet, USB gadget mode, WiFi drivers, virtualization systems, SMB file sharing, and of course more.
One benefit to the architecture of the Linux kernel is that typically all the fixes will arrive in a single kernel update, but when almost every week brings critical updates and a new kernel, patch fatigue is a real thing. Either users stop applying every update, or the uptime and testing requirements of a company prohibits constantly updating and changing servers.
Duress Passwords Aren’t Necessarily a Good Thing
The security-hardened Android variant Graphene, is in the news this week for the use of duress passwords.
A duress password is a mechanism where a second PIN or password can be used to initiate a device wipe. The hope is that in a situation where you are compelled to unlock a device, providing a password which then wipes the device is a preferable option.
The legality of a duress password depends on the environment it is used in. The United States Customs and Border Patrol claims that by wiping a device during an inspection at the US border, Samuel Tunick destroyed evidence and property in violation of federal laws. The issue is compounded because the stop happened at a border, where many US laws against search, seizure, and the availability of a lawyer are suspended, even for US citizens.
The inclusion of duress passwords, and their cousin hidden encrypted volumes, can sound like a good idea, but can place users in serious danger when in situations with less strict rules of law. Having the ability to wipe data sounds great in isolation, but protestors, human rights workers, and other targeted groups have faced direct and physical threats under some regimes. Facing retaliation for wiping a device, or facing physical violence before providing an unlock code out of fear that it might wipe a device, can be a real risk for some.
FreeBSD Fixes a WireGuard Bug
FreeBSD has issued a security update pertaining to the WireGuard VPN implementation.
WireGuard is a modern VPN with excellent performance even on low-end systems, and which has implementations on basically every platform. The FreeBSD implementation, however, didn’t fully validate VPN packets, accepting packets without checking one of the cryptographic validation measures.
Attackers are able to inject data to a FreeBSD WireGuard implementation if they are able to guess some attributes of the connection, and able to fully modify the data in the VPN if they are able to intercept the packets.
The bug impacts any FreeBSD user of WireGuard. FreeBSD has released updated kernels.
This Week In Security: Another Record Patch Tuesday, LAME Is More Secure, Secure Boot Is Less Secure, And Milk Malware
Following the reports last week using the Windows Global Device ID (GDID) in tracking a malware operators behavior, here is a comprehensive write-up about what goes into the GDID and how it is used. It’s worth noting that the GDID itself was not used to catch the malware operator, however once a suspect was identified, the GDID was used to correlate behavior across various Microsoft products on the Internet.
The GDID is generated and assigned during a Windows install, but a re-install of Windows will generate a new GDID. Developer [SmtimesIWndr] tracks the generation and tracking of the GDID through the various Windows libraries and services, identifying where it appears to be created and how it is passed to other services like Azure.
Worth noting is your GDID is a unique, personally identifiable piece of information; if you go exploring and extract it from your Windows install, be sure to keep it private!
LAME mp3 updates
Those of us who were around for the dawn of MP3 files may remember the LAME encoder and library. After almost 10 years, there is a new LAME release.
Notably, this includes two security fixes, one for a stack buffer overflow based on malicious input to the Blade encoder, and an integer underflow in the AIFF header parser. Both of the fixed bugs feel very old-school, which seems appropriate given the age of the library and most of the related code.
Buffer overflows impacting the stack are some of the simplest and most direct forms of vulnerabilities, where it is possible to write past the end of a buffer and control how the function returns and instead execute arbitrary code. Integer under-flows, similarly, impact memory management; usually caused by allowing a variable that stores the size of a buffer to go negative. Since sizes are typically unsigned positive numbers, a negative is interpreted as an enormous positive number, writing past the proper buffer length.
Despite the new findings, the LAME codebase has been extremely resilient over the years, and considering the number of programs that likely still use LAME under the covers to process audio, seeing the project wake up with security fixes is great news.
Recovering Passwords from BIOS
Researchers have found a vulnerability in Dell BIOS code that allows extraction of the administrator password from the BIOS flash chips, either with physical access via a flash programmer, or via administrator or root level access to the operating system and reading the contents of the flash chip.
Dell used a 20 byte key to encrypt a 32 byte password field: for any admin password of 12 characters or fewer, the password is stored in completely plaintext. For longer passwords, characters beyond the first 12 are encrypted – but the random bytes are computed from the first character of the password mixed with fixed device data, yielding only 256 possible encryption seeds for the remaining bytes.
Using the BIOS admin password for evil requires local access, so the attack surface is small, however as the researchers note it controls the boot order and may allow an attacker with physical access to then boot an unsigned OS or bypass full-disk encryption, so it’s serious.
Continue reading “This Week In Security: Another Record Patch Tuesday, LAME Is More Secure, Secure Boot Is Less Secure, And Milk Malware” →
This Week In Security: Microsoft On Microsoft, Register Your Domains, Linux On ARM, And FreeBSD Joins The File Cache Club
Supply chain attacks continue, with Microsoft’s own open source Azure repositories being automatically disabled by GitHub following a compromise of the packages by the Miasma worm.
OpenSourceMalware reports that the infection resulted in 73 Microsoft-related package repositories being flagged and taken offline in a little over a minute by the GitHub automated security system, with over 40 repositories being related to Azure and the rest distributed across the Microsoft organization.
The center of the infection appears to be the Microsoft Durabletask package, which was previously compromised in May and used to push infected packages to PyPi. Considering that all of the supply chain worms also steal credentials for every service they can find in the build or developer environment they infect, it seems likely that credentials stolen in the original attack were never properly disabled.
Disabling the repositories can help stem the infected packages and GitHub actions from spreading and infecting more organizations, but of course any build processes depending on those packages will not function. In May, the Durabletask package showed over 400,000 downloads per month.
The OpenSourceMalware report includes a full list of the impacted repositories.
Microsoft Fixes GitHub Token Exploit
Microsoft has finally fixed a bug in GitHub which could steal a GitHub authentication token with access to all of an accounts repositories via the embedded web-based VSCode editor which is part of GitHub itself.
Ammar Askar discovered the bug and discusses it on their blog; by manipulating the sandboxed VS Code into treating an embedded web view as user keyboard strokes, it is possible to to cause it to install a VS Code extension which is then used to exfiltrate the GitHub authentication tokens of the user using the embedded VS Code instance.
Continue reading “This Week In Security: Microsoft On Microsoft, Register Your Domains, Linux On ARM, And FreeBSD Joins The File Cache Club” →
This Week In Security: Plenty Of Patches, Replacing Old Gear, And Phrack Calls For Papers
When Friday the Thirteenth and Patch Tuesday happen on the same week, we’re surely in for a good time.
Anyone who maintains any sort of Microsoft ecosystem knows by now to brace for impact come Patch Tuesday; March brings the usual batch of “interesting” issues, including:
  • Two high-risk Microsoft Office vulnerabilities (CVE-2026-26110 and CVE-2026-26113), both of which allow execution of arbitrary code with no user interaction other than opening a hostile file. Vulnerabilities like these are especially dangerous in environments where transferring Office documents is considered normal, such as (unsurprisingly) offices, but also for home users who may not be savvy enough to avoid opening hostile files. Arbitrary code execution allows the attacker to run essentially any commands the user would be able to run themselves, typically leveraging it to install remote access or keyboard logging malware.
  • Excel gets a different vulnerability, CVE-2026-26144, which allows leaking of data through a cross-site scripting vulnerability. Coupled with CoPilot Agent, this can be used to leak contents of spreadsheets, again with no direct user interaction.
On the server and container side, this month includes a fairly typical collection of patches for SQL Server, and vulnerabilities in the Microsoft-hosted device pricing and payment orchestrator services, which have been automatically patched by Microsoft. Continue reading “This Week In Security: Plenty Of Patches, Replacing Old Gear, And Phrack Calls For Papers” →
