X-Ray A PCB Virtually
If you want to reverse engineer a PC board, you could do worse than X-ray it.  But thanks to [Philip Giacalone], you could just take a photo, load it into PCB Tracer, and annotate the images. You can see a few of a series of videos about the system below.
The tracer runs in your browser. It can let you mark traces, vias, components, and pads. You can annotate everything as you document it, and it can even call an AI model to help generate a schematic from the net list.
Continue reading “X-Ray A PCB Virtually”
