While most of us are familiar with pneumatic transport systems by their use at drive-up bank windows, these systems are also commonly found in hospitals ferrying samples around. When [Aidan] was in the hospital, he asked how this series of tubes routed samples from many different floors to the lab and back again. Well, give him an old tube to play around with and he’ll eventually come up with a way to record the inside of one of these pneumatic tubes, giving some insight into how this system actually works.
When asked, a tech that uses this system on a daily basis described it as a very basic physical Ethernet that sucks and blows through rotary junctions and physical hubs to route packets to different areas of the building. [Aidan] wanted to record a tube’s travels, so he wired up a small HD camera, a bunch of LEDs, and a few batteries. Sending this recording sample container revealed some of how this pneumatic system works; the containers will travel forward and stop before reversing through one of the rotary switches. You can check out the flight of the container in the video below.
Of course there are other glimpses of how stuff travels through the unseen world of getting from point A to point B. Here’s a time lapse camera going on a trip via DHL just for kicks.
Continue reading “What The Inside Of A Pneumatic Transport System Looks Like”
