Xerox has announced a breakthrough in printable circuits. They’ve developed a conductive ink called “silver bullet” that can be printed on many different types of substrate to create circuits. The key part of the new ink is its lower melting point. Plastic film substrate melts at 150 degrees Celsius but the ink is liquid when ten degrees cooler to avoid damaging the film. This begs the question: how do you then solder components to the circuit?
The benefits of printable circuitry are obvious. Aside from cheaper and easier RFID, disposable circuits like greeting cards, and fabric-based electronics, we’re hoping this will facilitate more environmentally friendly PCB fabrication. That really depends on the ink’s production process and the resilience of the resulting circuitry.
[via Gizmodo]
