Simple Plywood Lamp Has Neat Hidden Switch
Shortly after the development of the electric light came the light switch, presumably. Of course, obvious switches are old-hat, and this neat lamp build from [Giovanni Aggiustatutto] goes with a design that’s altogether more coy.
The lamp itself is a minimalist modern design, with a cube-like body constructed out of plywood. It was easily constructed by simply stacking up several layers of plywood to create the form. Inside the housing, a bulb holder was installed hooked up to a Shelly smart relay to enable the lamp to be used as a smart device. The relay also has a switch input for direct control. This is hooked up to a micro-switch that is tucked into the base. Tilting the lamp to one side triggers the micro-switch and turns the lamp on and off as desired.
Overall, it’s a simple build that is elegant and functional. It eschews switches on the lamp cord and other fussy details, while featuring both smart control and a direct switch as well. We’ve featured some other great lamps before, too. Video after the break.
Continue reading “Simple Plywood Lamp Has Neat Hidden Switch” →
