Windows security problems due to insecure drivers is nothing new, but this one is kinda special. Plug in a Razer mouse, tell the install dialog you want to install to a non-standard location, and then shift+right click the Explorer window. Choose a powershell, and boom, you now have a SYSTEM shell. It’s not as impressive as an RCE, and it requires hands-on the machine, but it’s beautiful due to the simplicity of it.
The problem is a compound one. First, Windows 10 and 11 automatically downloads and starts the install of Razer Synapse when a Razer device is plugged in. Note it’s not just Razer, any branded app that auto installs like this is possibly vulnerable in the same way. The installation process runs as system, and because it was started automatically, there is no admin account required. The second half of the issue is that the installer itself doesn’t take any precautions to prevent a user from spawning additional processes. There isn’t an obvious way to prevent the launch of Powershell from within the FolderPicker class, so an installer running as SYSTEM would have to go out of its way to drop privileges, to make this a safe process. The real solution is for Microsoft to say no to GUI installers bundled with WHQL signed drivers.
Continue reading “This Week In Security: Through The Mouse Hole, Zoom RCE, And Defeating Defender”
