Microgram electrobalance
posted Sep 27th 2005 9:30am by Eliotfiled under: misc hacks
As with most precision equipment, microgram scales are usually very expensive. The close tolerance machining of sapphire pivots and computer control add to the cost. Not all of those components are necessary though. This article from Scientific American demonstrates how to build a simple microgram balance using a salvaged galvanometer. Once calibrated, the output voltage will have a direct linear relationship to the weight. There is a more recent version of this project that uses a microcontroller to overcome static friction and auto center.
wow, a microgram balance. That hack came out about 5 years ago… But in any case, they can be made quite a bit simpler, see http://www.sci-spot.com/Mechanical/balance.htm for an even simpler design; with a digital readout!
