I received some good stuff via the tips line while I’ve been making an extra stop after Shmoocon. I spent the day helping my less project endowed family run some new wiring (and made some awesome sparks in the process.)
[Damian] sent in his customized version of the classic Atari 2600 adventure game.
[iraqiGeek] sent in his efforts to use the six-axis controller. He used lib-usb and PPJoy to create his own app.
[HP Friedrichs] sent in this interesting post on building military style power supplies. Good stuff if you’re into building your own gear and like interesting chassis designs.
[John] sent in his version of the new KITT’s light bar. (You know you watched it.)
Got something good to share? Use the tips line.
Subscribe for weekly videos
The power supply looks cool. Also, making sparks when wiring is fun, unless someone gets zapped… I assume no one did, or you’dve mentioned it, correct?
Thanks for the SIXAXIS link — I spent a *long* time wrestling with mine a week or so ago. For basic SIXAXIS gamepad use, Google “sixaxisdriver.exe” — it’s Japanese, but once you install it there’s not much to look at, and I think it’s in English at that point anyway. There’s a “Sixaxis_en.exe” driver that went around about a year ago, but a lot of people (myself included) had problems.
This is interesting, though — could be a good way of harnessing the gyros in that sucker. Of course, the linked-to guy references Carl Kenner (sounds like a bit of a nutjob, but he’s all we’ve got =-), and I thought GlovePIE already had SIXAXIS support, sooo…. I dunno.
On the power supply:
I built something very similar to run my ham radio stuff.
I found a similar case, but mine was painted navy gray and originally held explosive bolts (very cool stenciling)
I was only aiming for a reliable 5-6 amps output at 12 volts since it was only intended to run my 2 meter handheld and maybe a light source, so I used a 7ah sla battery and an 8 amp digital power supply to make what I called an “uninturuptable DC power supply”.
Very basic, it uses a relay for switching and a fully automatic charger to maintain the battery.
I don’t like how meters can get messed up with rough handling, so I used some basic colored LEDs as indicators for power.
I should take some photos of mine to share since it’s so similar.
Bummer I finished it just in time to stop being so active in ham radio.
73 de n2nlq!
