Solar engine
We spotted [Kerrin Mansfield]‘s lovely solar engine on ladyada’s rantings. It uses 16 1/8th inch solar cells to collect power. At night, an orange LED pulses at .2Hz. He doesn’t have a specific write up on the construction, but from the component layout, it looks identical to [Gareth Branwyn]‘s schematic in Make 08, which you can find in the PDF.
Comments
  1. Dang Elliot, you’re a beast with the hacks today.
  2. martin says:
    i think i’ll make one of those. looks neat and simple.
  3. Marcus says:
    This is actually a BEAM bot. Schematics can be found here: http://www.beam-wiki.org/wiki/index.php?title=Pummers
  4. kerrin says:
    That is indeed the schematic I used, though I should say I found it amongst the documentation on solarbotics.com. Just replace the batteries with a BIGFARADS cap, experiment with resistor values to get the desired pulse frequency and woohoo!
    Thank you for blogging this. 8^)
  5. kerrin says:
    After more detailed reading the PDF this blog entry refers to, I’d like to add that if you choose a smaller electrolytic to store power — I used a 2.5V 3.3F Gold capacitor for aesthetic reasons — then you should use the 74HC240N octal inverting buffer IC, instead of the 74AC240, due to the former’s lower operating voltage and increased stability at lower voltages.
  6. Tony says:
    Anyone have schematics to make this?
    -Thanks
  7. Tony says:
    the more detailed the better. I am new at building.
    -Thanks again
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 94,461 other followers
