Check out this awesome tool that [Alfonso Martone] built and wrote in to tell us about: a pin plotter made entirely from Lego (except for the addition of a pin in one brick). [Alfonso] has managed to get 33dpi resolution with a “printable” area of 90x70mm. The NXT device reads 1bit bitmapped images in PBM format and outputs onto a sheet of paper, which is held in place by Lego pneumatics pushing against rubber Lego bricks. Output is not what you might call speedy, though: it takes 35-40 minutes to output a drawing with 1,500 holes.
[Alfonso] has managed to capture our hearts with this awesome piece of work, which we’d love to backlight and put in a frame on our wall.
[Thanks, Alfonso Martone]
Good!
You should make the frame out of lego.
I saw the title and thought bullsh1t. i figure the frame was lego, but the guts were from a real plotter. Wow! Great hack!
joe: The frame is indeed made out of Lego.
Great hack!
there was a actual lego kit of a ink pen plotter i wanted when i was a kid but never got. look here http://guide.lugnet.com/set/8094
yeah, i think someone did this with real ink with the original mindstorms set
i remember seeing a lego scanner a while back, so this is nothing new. still cool though :)
You could buy a kit to do this that came with software for the BBC micro to do this. I borrowed the kit from a college and made it myself a few years ago. It wasn’t great but it worked.
The best thing is bra at 22-back-view.jpg on his site
You could make a pretty cool lampshade with this. There were several homebrew LEGO printers/scanners/copiers done back in the day when Mindstorms 1/1.5 came out. I built a copier in 1998.
may i ask what kind of software do you use
Next step make a fabber!
I would never think of cosplaying that hehe I cant believe it was done, i guess it was bound to happen do to the shows popularity.
Hello, your website doesnt show up properly under the browser Demonecromancy v 6.4 perhaps its a problem with the wp theme?? https://bestblackmetal.wordpress.com/2015/11/26/phantom-demonecromancy-the-best-of-black-metal/
