EVIC engine
posted Jun 24th 2009 3:00pm by Steve Watkins
filed under: misc hacks, transportation hacks
evic
The EVIC is a computer controlled internal combustion engine, utilizing a cam less solenoid actuated valve system. In addition to intake and exhaust valve control, the processor also handles ignition timing. With dynamic valve timing, it is possible to make an engine more efficient. Where a classic combustion engine would wastefully burn fuel, the EVIC can skip power cycles which are not needed. By increasing the valve duration, the CPU enables easy starting. The latest is the EVIC Mk3 which adds an exhaust valve sensor, and 3:1 solenoid leverage. There is a photo gallery with several EVIC engines. The Mk2 Twin is demonstrated in the video embedded below.
Recent Posts
Reader Comments
Hack a Day serves up fresh hacks each day, every day from around the web and a special How-To hack each week.
Send us your hacks
Hacks
Resources
RSS newsfeeds
Powered by WordPress
Most commented on (30 days)
Recent comments
