Update: Samsung TV firmware hacking
[Erdem] sent us an update on his work with the SamyGO project. You may remember this Samsung TV firmware hacking initiative from our post back in October. Since then many more TV models have been added to the compatible list. They have also worked out a way to defeat the AES encryption and RSA signature checking on the CI+ devices. Want to lend a hand? Take a look at the compatibility table on the main page and see if you have one of the TV models they need testers for. Otherwise, read the wiki, hit the downloads page, and unlock the hidden abilities of your boob tube.
Comments
  1. wdfowty says:
    i was wondering what happened to this project. if only i had a samy…
    btw, “boob tube” link is broken
  2. Tom says:
    Whoa, HAD brought down en.wiki
  3. _matt says:
    wow, where’d wikipedia go?
  4. brian4120 says:
    @Tom
    I think Wikipedia is having intermittent downtime at the moment. I’ve been seeing a few people mentioning that they can’t reach it.
  5. Shadyman says:
    Hack-a-day effect? Not likely :P
    European servers shut down due to overheating, and their failsafe DNS redirection failed. http://news.slashdot.org/article.pl?sid=10/03/24/1816240
    Though, this is a pretty nifty hack :)
  6. chris says:
    What am I missing? Why would anyone want to hack a tv? It only has hardware to be a tv and it allready is a tv.
  7. soopergooman says:
    Will this help to make my LTNF series junko work better? Or atleast give it more features?
  8. wifigod says:
    @Chris
    You haven’t been following TV news lately, have you? For starters, IIRC, this will unlock extra calibration menus for the TV that can boost the feature-set a little bit. More importantly, newer Sammy’s come with web-enabled widgets that run directly on the TV w/o need for a PC. If people can unlock the firmware for them, they can potentially program their own widgets and have the TV start to interact with the web for useful activities.
  9. Dustin says:
    @wifigod
    i can see it now… your tv twittering what tv show you’re watching
  10. Paul says:
    What features does this add? The website didn’t seem to have a solid list.
    I have seen some LG’s that can play xvids directly from the ethernet.
  11. h_2_o says:
    the video feature is probably the most interesting to me anyway. lets say a widget could be developed to play videos from a nas or some other type of remote storage, bye bye WD media player.
  12. nubie says:
    Re bricking:
    “If you flash faulted dummy flash images and TV become bricked, you needed to unbrick it by ExLink cable. Again, you can revive your TV but this situation will release lots of adrenaline to your body and make you feel hot and cold same time. ”
    You just said a mouthful http://sourceforge.net/apps/mediawiki/samygo/index.php?title=Is_this_tools_avoids_my_warranty%3F
    Made me grin.
  13. David Sutherland says:
    One nice feature looks to be to add NFS browsing. Why NFS over DLNA you ask? Well, besides the issue of perhaps your NAS only support NFS right now (Open Media Vault is coming but not out yet)…
    “* Via this method you can use features like FWD, RWD, PAUSE etc. ( which for some [wierd] reasons are lacking with DLNA )
    * Some Container Formats & Codecs appear as not supported via DLNA but work fine when opened via NFS
  14. nyder says:
    I have a sammy tv, 1080p, and if you ever tried to play a PS2 or similiar older console on 1080p, then you know how bad it looks.
    This hack will allow me to make it so I have borders around the lower resolutions, then automaticly stretching them.
  15. filjoa says:
    hi
    someone know if is possible read kmv with DTS on UN40B6000? and wifi, work?
    I only goto advanced options and change model to B7000 for I can read divx with an USB.
    best regards
  16. Decepticon says:
    i would really LOVE to try this, but I also don’t want to brick my brand new TV. I think I’ll stick with using my PS3 for my multimedia needs in the living room. That is until I can piece together an HTPC. Nice work though. It would be nice to see better widgets on my samsung since the only useful one for me was the weather.
  17. dex says:
    Hey guys, love this project, still looking forward to something of use coming out for it.
    As far as i can tell this project only applies to plasmas and LCD’s, i got a LED tv recently with the following firmware: T-CHL5DAUC-2001.1
    Looking forward to seeing USB supported movie playback on it :)
    xD
    Cheers guys
  18. pawel says:
    how i can hack samsung LN46A750 ,maybe somebody know ???
  19. tim says:
    Anybody know much about the main I2C bus on Samsung LED TV’s? I’m trying to snoop the I2C to get the config data for the audio amps on the board but I keep getting corrupted data (and it reboots the TV sometimes). Maybe this could be found in the firmware?
  20. mayo says:
    I own a B8090 and playing *mkv with dts is not supported. I would really love to get a working hack passing the dts signal to the optical output.
  21. sergio says:
    I have updated my led tv with an incorrect firmware (i guess so because my does not work after that). Did anyone know a way to reset to the previous firmware? Take in mind that the tv right now does not recognize any command from the remote control, the tv turns on and off constantly by itself (i have to umpluged). Thanks in advance for your support.
  22. rob says:
    hi sergio, any luck yet with your dead tv?
  23. pawel says:
    I have Samsung 58 plasma PN58A550S1F and dont have option to watch movies from USB , I have only pictures and music . Anything any software hacks ?
  24. Vitor Viegas says:
    It liked to know if I can install firmware and software of the D7000 in the C7000. This because in the C7000, service SMART TV does not allow function SMART NET. If it will not be able, as I can have in the C7000, function SMART NET?
  25. garrett says:
    i have a samsung ps42a410 and cant use the usb to lay media any hacks for this ????
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
