Making MSATA Work With Mini PCI Express
[Trucki] wanted to upgrade the internal storage on his JooJoo. There’s an mSATA connector inside but devices that use that protocol are hard to come by and when you do they’ll cost you and arm and a leg. He knew he could get solid state drives cheaply that use the mini PCI Express standard, which is mechanically compatible with mSATA. So he set out to alter a mini PCI Express device to work with the mSATA protocol. This entails swapping the transmission lines and rearranging the voltage traces on the connector. To handle the TX- and TX+ lines he desoldered their decoupling capacitors and realigned them to trade their signals. For the 3.3V lines he had to cut the feed and solder jumper wire to the correct pads.
This is some nice work which let him add a 32 GB drive for just sixty Euros. Since the device only comes with a 4 GB SSD an upgrade is almost mandatory if you’re planning to install an alternate OS on the Joojoo.
17 thoughts on “Making MSATA Work With Mini PCI Express
  1. This has NOTHING to do with mini PCI Express, he modded FLASHCON SSD to mSATA standard. Flashcon is something ASUS came up for EEE mini netbooks. Its SATA in mPCI connector, later more manufacturers agreed on a standard and called it mSATA.
  2. I know the JooJoo hackers have been looking for ages for ways to upgrade their storage space on these things. Previously the only way to do it was to buy bulk drives from the JooJoo SSD manufacturers at extortinate prices.
    So, huge props to @Trucki.
    It’s just a shame the JooJoo’s not produced any more, the specs are pretty awsome compared to the competition, once you get rid of the stock OS, of course.
  3. @zeropointmodule
    There’s no need to hack them. They’re standard ZIF socket PATA drives. Same connector as the iPod hard drives, just with a thicker (Hitachi, IIRC) ribbon cable. The Aspire Ones, unlike the Eee’s, used standard components for their models. Have a 8GB model AAO, and yes, those SSDs are worthlessly slow. I rerouted one USB port to be internal and booted Linux using a SD/USB Card Reader. Was loads faster than the internal SSD.
    Shame the left side SD slot isn’t bootable. Would have saved a lot of headaches.
  4. Is it possible to do it the other way round – make an mSATA device work in a Mini-PCIe connector?
    I have an mSATA SSD (OCZ Nocti 30GB) and want to install it on a board that has a Mini-PCIe slot, but doesn’t support mSATA.
  5. Has anyone a working link of the dead forum, or the information posted there?
    I have a spare Kingspec 64 Gb mSATA SSD and I think this hack could be usefull to install it on my Sony VAIO FE computer (whici also has a spare miniPCI-E connectort).
    Thanks!!
  6. Hello all!
    I know this post is more than a year dead, but I would like to know if there is someone with a copy of the linked post. I’ve searched all around internet and Google is already laughing at me for asking it so much :-P.
    The original link is dead and I think that this hack could be great to use a Kingspec 64 Gb mini PCI-E SSD I have on a mini PCI-E connector available in my Sony VAIO FE computer.
    Thank you!
Leave a Reply to zeropointmoduleCancel reply
