Crank-arm Style Hexapod
The latest robot out of Nolebotic is Al.I.S.E, or Aluminum, Infrared Scanning Entity. Don’t let the name fool you, its a pretty simple take on the classic hexapod walking platform using a crank arm and leavers made into the legs.
The body of the robot is made out of aluminum which is pretty easy to work with at home, lightweight, and sturdy. Bolted to the body are a pair of beefy gear head motors, a 9.6 volt rechargeable battery pack, along with a basic stamp 2 and its own 9 volt supply, and a Solarbotics 1198 CMD driver board.
Obstacles are handled right now with rudimentary infrared detectors and emitters, but it seems to work pretty good avoiding some library books in the demo. Combine that with clean mechanics and a pretty good stride and this thing can get up and move pretty quick.
One thought on “Crank-arm Style Hexapod
  1. Looks like it moves in the same way as a Hexbug:
    Those things actually only use one motor, in one direction it moves the bug forward, in the other direction it only engages the legs on one side and causes the bug to back up while turning. It looks like this hexapod has a motor for each side so it can skid-steer like a tank.
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
