Multicolor 3D prints the hard way
After drooling over the Makerbot dual-head extruder, [Brett] decided to get off his duff and make a proper multi-color print.
[Brett] has been making a few bottle openers for friends and has been successfully experimenting with switching filaments in the middle of a print. For his “Saturday Killer” bottle opener, he decided to push multicolored prints to the limit. For the “Saturday Killer,” [Brett] decided to print an abridged version of the classic Simpsons quote, “Beer, the cause of, and solution to, all of life’s problems” on the side of a bottle opener in 4 different colors.
The files necessary to print the Saturday Killer were generated in OpenSCAD. The general principle behind the design is to generate separate .STL files for the bottle opener and the sides, split those files into 2-layer chunks, and print those files while constantly adjusting the z-height. It’s not called the Saturday Killer for nothing, so [Brett] had to change the color of his filament 25 times.
A much simpler version of a complex multi-color print is [Brett]‘s Shepard Fairey inspired self-portrait. Still, we’re thinking a dual head extruder is somewhere in [Brett]‘s future. At least he’s got the technique down.
Comments
  1. Regulus says:
    I chatted with Brett at NY Makerfaire, he’s a pretty awesome dude.
    This work is fantastic, and makes me wonder why there are no automatic filament changers.
    • DoktorJ says:
      The complexity of changing filament in most diy 3d printers is not trivial. Dual heads are actually much simpler, even though it might seem like it should be the other way around. My Reprap is still in the build stage and I’ve gone through 3 extruder designs before it’s even functional. The most recent is the same as what is used on an Orca and is by far the simplest to change filament on, but even it requires removing some nuts and springs, folding back the piece the holds the bearing and threading the new filament, also if the new filament has a different width, that requires even more tweaking. This would also likely result in bleed-over from the previous color. So, at least for now, dual extruder heads seem to be the best option.
  2. RunnerPack says:
    That’s pretty impressive work.
    I think I would try to solve the problem with uncolored filament and an extruder that adds pigment as it’s extruded.
  3. Simon says:
    Next up:
    Make shot glasses with the original quote.
  4. Brett says:
    Hi everyone, thanks for the positive feedback.
    one of the things missing from the color-change discussion is the transition zone when you switch colors. It’s not as though it goes immediately from one color to the next. It usually takes 10-20cm of extrusion before you’re completely on to the next color. I added a picture of all my color-change scrap to the flickr set:
    http://www.flickr.com/photos/38917611@N08/6263685278/in/set-72157627783358031
    @Simon that is a great idea. I’ve worked up the font such that it can be rotated, so it wouldn’t be that tough to make. Now spiraling it up the glass? THAT I wouldn’t do without dual heads.
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
