Dot matrix printer spits out any tweet mentioning @KWF
Earlier this month, [Kenneth] picked up an old dot matrix printer at the Silicon Valley Flea Market and subsequently found two cases of tractor feed printer paper. It’s a marriage made in heaven for a dot matrix twitter printer.
[Kenneth] used a BeagleBone - a tiny single board computer running Linux – to connect to the Internet and fetch any new tweets mentioning KWF every minute or so. The BeagleBone spits out these tweets over the USB port which is connected to the ancient printer by means of a cheap adapter cable.
Interestingly, [Kenneth] wrote the code for this project as a shell script. A lot of effort went into scrubbing the input of any escape characters, but he still implores his admirers to not attempt to break his project.
In case you’re wondering, at couple Twitter accounts announced this post’s headline to the Twitterverse when this story was published. This should have immediately sent [Kenneth]‘s printer into motion, recording that harsh mistress that is sending a build log of a Twitter connected device into Hackaday.
After the break you can see [Kenneth]‘s demo. Be sure to share this post on Twitter!
Comments
  1. Jedi says:
    i guess
    i’m too retarded to find the webcam feed.
  2. nice clean shell script code, but I can’t figure out where he’s removing the control characters.
    Typically, I’d pipe the output of curl right through `tr` to remove or transform anything that might make my printer unhappy.
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
