Hacking laser tag and building custom guns
As [Brad] over at the LVL1 hackerspace watched his friend build a Laser tag/tazer mashup for Makerfaire Detroit 2012, he noticed these new laser tag guns were really cool. These Light Strike guns have an impressive array of electronics for a $30 toy, but there was still much to be desired. [Brad] decided to reverse engineer these guns and work on a drop-in replacement for the game’s electronics so people like his friend can hurt themselves more easily.
The Wowwee Light Strike guns operate with IR LEDs, so the obvious solution for decoding the laser tag protocol would be the Arduino IR remote library. [Brad] had a bit of trouble getting his Teensy to read the IR data correctly, but after connecting everything up to a logic analyzer he had the data format figured out.
Now [Brad] has the Light Strike data format figured out and is theoretically able to make his own guns that are compatible with the off-the-shelf laser tag system. It’s also possible for [Brad] to extend the capabilities of this laser tag system by using the ‘health’ function to create a medi gun, or build a gun with a larger magazine for a laser tag mini gun.
If you’d like to build your own version of laser tag compatible with the Wowwee Light Strike, you can grab all the code on [Brad]‘s git.
Comments
  1. cde says:
    http://rich.whiffen.org/2011/10/light-strike-decodes-so-far.html has more information on them as well.
    And hey, kmart has some of these on clearance last I saw like 3 weeks ago. The practice target (that looks like an arc reactor, with a rgb led inside) was at 2.50.
  2. boondaburrah says:
    BRB gotta build real life TF2.
  3. Galane says:
    Nothing beats the style of the original Worlds of Wonder Lazer Tag guns.
    Unlike every other similar system, they were black and compact and sleek, looking like really futuristic weaponry.
    The others look like something kitbashed from leftover model kit parts, like so many 1970′s and 1980′s SciFi TV and movie spaceships.
  4. BoKu says:
    Looks like the GIT has been moved to here
    https://github.com/LightStrikePlusPlus/LightStrikeDecode
  5. mixadj says:
    Very random comment relating to lasertag. The commercial grade lazertag systems use an xbee for wireless and report to a central game server. They also use ibuttons to store player data and allow for system login through lazertag vests. Pretty neat stuff. I’ve worked on a few of the vests and have toyed with the Idea of trying to build my own that would integrate with the commercial systems.
  6. Chris Conrad says:
    Here’s a LVL1 Laser Tag video I took last week: http://www.youtube.com/watch?v=HTa84en9mXs
  7. imzorro says:
    Been there, done that, except we stuck arduinos in ours :)
  8. mike says:
    what about hooking a small (low power) tazer up to an arduino and the ir receiver
    give you a small zap each time you get hit, and a bigger zap if you take too many hits
    • Hitek146 says:
      This would be cool, along the lines of the previous Hackaday post about the zapping force feedback controller.
      Even more cool would be to replace the IR emitter in the(now oversized) housing with a real high-powered laser module. Much more realistic, although you would need to make sure every participant wore the appropriate wavelength blocking visors for their eyes…
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
