Build Your Own Brushless Motor
Building an electric motor from a coil of wire, some magnets, and some paper clips is a rite of passage for many budding science buffs. These motors are simple brushed motors. That is, the electromagnet spins towards a permanent magnet and the spinning breaks the circuit, allowing the electromagnet to continue spinning from inertia. Eventually, the connection completes again and the cycle starts over. Real brushed motors commutate the DC supply current so that the electromagnet changes polarity midway through the turn. Either way, the basic design is permanent magnets on the outside (the stationary part) and electromagnets on the inside (the rotating part).
Brushless motors flip this inside out. The rotating part (the rotor) has a permanent magnet. The stationary part (the stator) has multiple electromagnets. By controlling the electromagnets, the rotor spins. With no brushes, these motors are often more efficient, they don’t generate as much electrical noise, and there is no danger of brushes wearing out. In addition, the electromagnets staying put make the motor easier to wire and, if needed, easier to cool the electromagnets. The principle of operation is similar to a stepper motor. Steppers are usually optimized for small precise steps. Brushless motors are optimized for spinning, not stepping.
[Axbm] built a clever brushless motor out of little more than PVC pipe, some magnets, wire, and iron rods. The plan is simple: construct a PVC frame, build a rotor out of PVC and magnets, and mount electromagnets on the frame. An Arduino and some FETs drive the coils, although you could drive the motors using any number of methods. You can see the whole thing work in the video below.
One interesting tidbit is the winding of the coils. [Axbm] put 600 turns of wire around each iron core (soft iron is best, although you can use stainless steel, which is easier to find). Instead of cutting the wire when done, he simply moved on to wind the next magnet. To keep the magnetic fields in the proper orientation, the winding of one magnet has to be in the opposite direction of the previous winding. So if you wind one magnet clockwise, the next magnet must be anticlockwise.
We’ve seen other brushless motor builds. We’ve also covered more sophisticated drivers.
11 thoughts on “Build Your Own Brushless Motor
  1. BAH!
    That’s more commonly known as a stepper motor, since no of Magnets = number of coils. This allows for maximum holding torque.
    A BLDC.. especially the ones referred to an inrunners, have dissimilar amount magnets and coils. They will have 3xn amount of coils.which can be wired in delta or wye configuration. Then they will have 3xn+1 or +2 amount of magnets. In that configuration the magnets will never be in phase with the coils allowing you to spin it much faster than you could with a stepper configuration.
  2. Anyone can be afflicted with VVS. For small monthly donation of only 65$, the cost of a single Starbucks coffee, we together wipe out this debilitating vlogging disease forever. Call now and make a difference!
    1. I had surgery to rearrange my face so the one eye is directly above the other so that VVS wouldn’t bother me as much, if only I had known about your campaign.
      1. That or they should just rotate the sensors so the most comfortable one handed shooting position results in the most desirable video. This is a UX problem as much as anything else.
        1. The camera matches the screen orientation so you can display the viewfinder in full screen. If the camera was in landscape orientation with the phone in portrait, you’d always see what you are shooting in a tiny letterboxed area in the middle of the phone’s screen- the sensor orientation has to match the screen orientation. IMO cameras/phones should just refuse to shoot video with the device in portrait orientation unless you enable it in software (preferably via a convoluted menu to discourage it being used unnecessarily).
Leave a Reply to konsgnCancel reply
