A Weird Kind of Printer
printer
[Benjamin] is just putting the finishing touches on his home-made, paper-stabbing, needle-printer!?
From a distance, it looks like the bare bones of a regular inkjet printer, but it’s not. Instead of an ink-head it features a needle — It’s kind of like a dot-matrix (hole-matrix?) printer. He’s using it for silk-screening masks, which we have to admit, must be pretty handy — it certainly makes soldering SMT’s less scary! It could also be used for embossing or even braille printing.
The frame of the printer is laser cut out of clear plastic, and two Nema 17 steppers drive the X & Y axes. A simple solenoid actuator provides the needle-stabby action. He’s controlling the whole thing using an Arduino, and sending the data to it using a call-and-response protocol to avoid any data losses. It was built for just shy of $200, which was his original goal for the project.
Check it out after the break!
[Read more...]
