Hackaday Links
[Dancerman] sent us a couple pdfs covering the Navy’s research on railguns which might show up on new platforms like the DD(X): first is NRAC’s Electromagnetic Gun Technology Assessment, second is slides from the Annual Gun & Ammo Symposium which covers the problems encountered when scaling a system up for ship use.
I was pretty tired of railguns by the time someone sent in the obligatory Powelabs link. So, I read about Sam’s Subaru 2.5RS engine swap and watched the sandboarding videos instead.
[george] knows that these a pretty common, but his laptop picture frame looks pretty good. He added WiFi and Bluetooth adapters to the empty battery bay so that he could have remote access and control the frame with his phone.
[Douglas J. Hickok] used a solar powered yard light to illuminate his Jack-O-Lantern. It ends up looking like a hat.
[tio.chorizo] doesn’t want to pay for the Nano lanyard headphones so he modified his stock ones. He made a large loop and then used heat shrink tubing to hold it in place. Here is a Coral Cache of his photos.
[seth fogie] pointed us to airscanner’s page of iTunes DOS/Spoofing attacks with flash demos.
If your Folding@Home system is chugging away and your looking for another project you could try setting up some diskless clients. [Grendup]
With a little butchering you can make your own in car DVD player. [the_eye]
A completely useless 2.5cc gas-engined turntable
This Engadget post has links to commercial clothing that has integrated controls and power. Now someone just needs to do it for cheap.
Cool Tools featured a blackbox for your car. It plugs into your OBD-II port and records the signals coming from your ECU. If you are in an accident it will have the information from right before the impact.
Cinematical highlighted the documentary Project Grizzly. It’s the story of Troy Hurtubise who built a bear proof suit and is now claiming he can see through walls/cure cancer.
7 thoughts on “Hackaday Links
Leave a Reply to sleighboyCancel reply
