Hack-A-Day reader [Mindaugasu] built this box for exposing copper boards to ultraviolet light before etching them. It has two banks of four 20W UV lamps. The box is lined with reflective foil. The banks can be controlled separately and the exposure time is set by an Atmel AT90. You can change the time using button panel and LCD. He’s got some example boards in his ARM development section.
