[Eddie], who made the Mac Logo LCD Mod, had posted a step by step tutorial on how to do it yourself. He basically just fully disassembled his MacBook, popped out the logo, put one from an iBook or Powerbook, then mounted a small LCD back there and routed it into a USB port internally. He says the extra electronics cause a tiny bulge in the monitor casing. We wonder if this couldn’t lead to stress damage on the main LCD in the long run.
[thanks Koray]
What happens when pressure is put on the outside cover of the laptop? Normally there is a small space between the lcd and the case, as designed, to prevent damage.
“What happens when pressure is put on the outside cover of the laptop? ”
then he will have to learn how to use his laptop backwards
I dont know what everyone else is thinking but I would rather cut out the entire monitor size and add a touch sensitive file. Yes the one I link is too big but once you calibrate it to the screen size all should be good. Then with some nifty coding when the screen is shut the outside monitor displays a yes/no box asking if the outside monitor is going to be used. Now you have a small sized tablet.
http://www.dealextreme.com/details.dx/sku.12561
Putting any constant pressure on an LCD panel will cause white spots to appear. Minor vibration over a long period of time will cause damage to the internal film sheets, which will show up as white spots. It’s a bad idea if you like your system…
I have to admit, it’s a nice touch, and reasonably well executed. Will apple follow suit? (are they even allowed to?)
To me the price is far too high for a “fun” mod of this sort. I know its the novelty factor and all that but what do you think of the potential in using a digital photo frame to do something of that sort?
Nice mod. i should implement this on my mac plus.
just found this
http://www.carcomputer.co.uk/component/page,shop.product_details/category_id,46/flypage,shop.flypage/product_id,322/option,com_virtuemart/Itemid,26/
about 175 usd
“about 175 usd”
for what ? for killing you battery life?
Wow. That Mac is now slightly gayer, and you’re $175 poorer.
Nice exchange.
They have done really wonderful work here���
I was thinking about opening up the LCD bezel in my wife’s macbook, finding the wire to the white glowing light, and just snipping it. I think the goal with hacking a portable computer should help extend battery life, not kill it faster.
Great tutorial, I will try to make it step by step
@James: The Apple logo on MacBooks is lit up by the LCD backlight. There is no separate light or wires to snip.
