Arduino “python” Integration
vivarium
[Cyberspice] informs us she likes snakes. Hey, who doesn’t? She’ll soon be adopting a lovely ball python and wanted to keep close tabs on the sensitive creature’s environment. To that end she assembled a network-enabled vivarium monitoring system based on Adafruit’s Boarduino (a minimalist Arduino clone), a TMP36 analog temperature sensor, Saelig’s WIZ810MJ Ethernet interface, and a common LCD screen. The Arduino rig periodically issues updates to a web server, which can then generate informative graphs using a set of PHP scripts (what, no Python?).
Okay, so we could probably count on one hand the number of readers in need of fancy reptile monitoring and still have fingers left over. There are countless other applications where networked sensor monitoring of this sort is a frequent necessity, so the article could be a good starting point for your own projects. There’s lots of source code to work with, on both the Arduino and web server sides. And the parts list demonstrates serious frugality: the Boarduino, the generic LCD, and especially the Ethernet interface; even with the breadboard adapter, this unit is about half the cost of the usual Arduino Ethernet shield, leaving more funds available for the snake food budget!
9 thoughts on “Arduino “python” Integration
  1. Interestingly enough I have a nearly identical set-up running with three sensors for my three cages and a USB run to my comp for monitoring. Instead of an LCD I use Python the language to whip up a monitor and log. its pretty nice equipment for reptile keeping and I’m waiting for someone to productize it any day.
Leave a Reply to placebo.3ffect Cancel reply
