[Tim Williams] likes to heat things up with this induction heater he built. At peak it can use 1000W and as you can see in the video, that’s more than enough power to heat, burn, and melt a plethora of different objects. The case design uses a center divider to isolate switching noise from the magnetic field with the whole unit housed in aluminum because it won’t heat up from stray magnetic fields. He’s selling plans and kits in case you want one, but we just don’t know what we’d use it for.
[youtube=http://www.youtube.com/watch?v=ro6Dt9g7Ohw]
[Thanks Arcen]
Can you make one that will take a 12v DC input from say a car alternator, and put out the same power and metal melting properties?
