USB Minecraft Portal
[Sprite_tm] had heard some time ago that middle of the road Nokia phones had some really interesting LCDs, they are 2.4 inch TFT’s with 320×240 resolution. He immediately got 3 beccause they are pretty low cost as well, and started working with them. Apparently these LCDs are self contained, meaning they have all the driver chips and memory on board, you just need to know the pins and commands. This too is fairly easy as they are somewhat standard setups and datasheets for similar models work in a pinch.
Once the things were working, what do you do with them? [Sprite_tm] decided to make a desktop minecraft portal. Since the animation is a bit complex in micro controller worlds, he grabbed one of the STM32F101CBs for their beefy cpu and got to work. Getting the texture from minecraft proved to be a bit of a bear as they are not static images, but are calculated on startup. A bit of C code on the PC quickly generates an appropriate pattern and is exported to the micro controller for display in its final home.
The case is made out of wood and once finished looks just like the “real” thing giving a presentation any “blockhead” would love to have on their desk.
12 thoughts on “USB Minecraft Portal
  1. Anyone who would want this on their desk obviously hasn’t met a ghast before. Otherwise this looks really well done.
  2. Those displays really are cheap, at least at ebay. I wonder what kind of performance he got with that STM32? Too bad those connectors are so hacker-unfriendly, I could definitely figure some uses for such displays.
  3. @zokier: I’m thinking of designing an adapter board, perhaps even with a nice ARM on it like the LPC1343 to control it. I may even start selling them if there’s enough interest.
Leave a Reply to MarkCancel reply
