Last Mile WiFi Over TV White Space
tv_wifi_gear
What do you do when you can’t afford broadband and no-cost WiFi is just out of reach?
That was the problem Rice University grad student [Ryan Guerra] was tasked with solving. A local Houston resident could barely tap into the free service offered in her area, so [Ryan] set out to extend the signal’s range using white space previously occupied by TV signals.
Using channel 29 which operates at 563MHz, his “Super WiFi” project utilizes standard WiFi protocols and can extend the signal’s reach up to a mile. The WiFi signals at the closest tower are piped through a prototype frequency translator, shifting the signal from 2.4GHz down to 563MHz, which is far better suited for long(er)-haul transmissions. The system does not use channel bonding just yet, so it is limited to using about 25% of WiFi’s maximum bandwidth, which is far better than no signal at all.
While the widespread practical use of TV white space will take some time to come to fruition, this is definitely a step in the right direction.
[Thanks Chris]
26 thoughts on “Last Mile WiFi Over TV White Space
  1. actually reading the article helps.
    ‘Guerra is part of a Rice team led by professors Edward Knightly, Robert Stein, Lin Zhong, and William Reed that last year won a $1.8 million grant from the National Science Foundation. The team’s goal is basic research on providing broadband in the TV “white spaces”—empty channels that the government recently cleared for use by unlicensed Internet providers. ‘
  2. A set of old Dish network dishes and bi-quad antennas as feedhorns will do the last mile very nice. I have been able to “burn” through wet trees for a 1/4 mile link with that kind of set up using 802.11b speeds. Far easier to do.
    If you have line of sight, I’d go laser. you can get far higher speeds. http://ronja.twibright.com/
  3. prototype frequency translator? what’s prototype about a step-down superheterodyne? the fact that it retransmits the IF?
  4. yeah I read the article, my point is that the basic technology for this is about 80 years old, unless I’m mistaken about the technique being used here. not that this isn’t a good idea, but saying prototype makes it sound like brand new technology.
  5. Yeah, like who would still use 8bit uC? So old…
    Or it’s like rebranding windmills “wind turbines” to give theme some kind of 20th century twist, because, at the end, the energy generated will be use somewhere to mill. So Middle Ages.
    Finding new purpose to old stuff… for a second I thought I was on HaD
    /This was just humour.
    But, for the record “A prototype is an early sample or model built to test a concept or process or to act as a thing to be replicated or learned from.” (Wikipedia)
  6. @fartface
    I think Ronja uses normal LEDs instead of lasers. And iirc it pushes ethernet directly to air, which may or may not be such a great idea.
  7. There will be a large explosion in devices using this “white space” in the near future. According to the new FCC rules, there are three classes of such devices. This particular application uses “fixed location” devices. Such devices need to have their GPS coordinates entered into a central database.
    In one way or another, all such devices have to interrogate a central database to assure non-interference with licensed users. Google is one of the three approved database administrators for this spectrum.
  8. Taking into account what you can actually build without complex optics, ronja’s scheme (baseband ethernet + training signal in inter-packet gaps) works as well as anything other, adding some kind of FEC might slightly help but also bring significant amount of additional complexity (which in hobbyist terms probably involves high-end FPGA).
  9. I don’t suppose there are any actual schematics and software listing so that we may build something similar?
  10. Cool project.
    I’m not sure where the craziness about re-purposing hardware and techniques came from, but you can probably blame the pharmaceutical industry for that. (Go natural, man.)
    I like the thought of using the white spaces for stuff like this, and envy these folks for their freedom to experiment and their ability to bring us projects like this.
    Keep it up!
  11. Having lived “out in the woods” with crappy, expensive ADSL for a while, I’m totally psyched for this. It lends itself to natural monopolies because hey, limited spectrum, so I can see towns jumping on this.
  12. I hate to be that guy, but if all you want is to run wireless Ethernet at a lower frequency, you can buy off-the-shelf 900MHz gear that will do a much better job (ie. full performance) with very little effort.
    What he’s done here isn’t novel or impressive.
