The folks at Return Infinity just released a new version of their BareMetal OS, a 64-bit operating system written entirely in assembly.
The goal of the BareMetal project, which includes a stripped-down bootloader and a cluster computing platform is to get away from the inefficient obfuscated machine code generated by higher level languages like C/C++ and Java. By writing the OS in assembly, runtime speeds are increased, and there’s very little overhead for when every clock cycle counts.
Return Infinity says the ideal application is for high performance and embedded computing. We can see why this would be great for really fast embedded computing – there are system calls for networking, sound, disk access, and everything else a project might need. There’s also ridiculously small system requirements – the entire OS is only 16384 bytes – lend itself to very small, very powerful computers.
With projects that are computationally intensive, we think this could be a great bridge between an insufficient AVR, PIC or Propeller and a full-blown linux distro. There’s just some questions about the implementation – we feel like we’ve just been given a tool we don’t even know when to use. Any hackaday readers have an idea on how to use an OS stripped down to the ‘bare metal?’ What, exactly, would need 64 bits, and what hardware would it run on?
Check out the Return Infinity team calculating prime numbers on their BareMetal Node OS after the jump.
[youtube=http://www.youtube.com/watch?v=ccLef8GLl6g&w=470]
WHAT ? JAVA ? FUCK YOU JAVA ! FUCK YOU C ! If you’re a dumbass, don’t talk with me, i’m sure that you can won some time and learn that we have a FCKING bullshits as “society”.
Is it possible to create Ubuntu is clone in assembly code entirely and works just fine.
it is working fine for 64 bit, does it work for cent os too??
As per my present experience I would suggest you to select TPMD Packers And Movers in Janakpuri for relocation The best thing about their is that we handle your belongings with a lot of care. And that is why no damage gets caused to them. If you want to get your belongings transported from one place to another without any damage, then hire us right away. they boast of being the most reliable Packers and movers in Janakpuri. You won’t even have to think twice before hiring them. Do try!
