Hackaday Podcast Episode 367: Radioactive Weather, Continuous Pickles, And Moon Junk
When Elliot Williams and Al Williams compare their notes on the week in Hackaday, you know you’ll get at least one or two bad puns. How bad? Tune in and find out.
This week, Tom Nardi visits several in-person events, and Elliot and Al talk about smart buttons, Itanium, ejecting things from a rocket, and the infinite pickle. Will Elliot build the coin flipper? Will Al use plasma at his next cookout? Hard to say.
For the can’t miss articles, this week, Al swept the category with a post on splices and another on what human junk is still sitting on the moon.
What do you think? Leave us a comment or record something and send it to our mailbag.
Download a copy of the podcast with an MP3 from our continuous audio pipeline.
News:
Mailbag
  • Got something to share for the Mailbag? Drop us a line. Already sent something in? Maybe send it again as we were… ahem… experiencing technical difficulties.
What’s that Sound?
Interesting Hacks of the Week:
Quick Hacks:
Can’t-Miss Articles:
6 thoughts on “Hackaday Podcast Episode 367: Radioactive Weather, Continuous Pickles, And Moon Junk”
  1. With Al talking about switching plastics from A to B and having to throw out the intermediate mixes. The dum dum lollipop factory does something very clever when they switch flavors. The intermediate lollipops get wrapped with a “mystery flavor” label since the output is somewhere between known existing flavors.
      1. C’mon guys, can we at least put [Al] in brackets, or make sure to use his full name? I kept reading this as AI, with predictable confusion.
        PS. On my bog-standard Linux Mint running Firefox, the lowercase L has a little serif when I am typing here, but that gets lost when turned into Hackaday’s font.
        …. I’m off now to download one of those “legible” fonts, then force it into use on Hackaday, and only Hackaday. Thanks for the rabbit hole :-/
  2. DIY power profiler: 100 mOhm resistor in the negative battery lead hooked up to an oscilloscope running at a slow roll. Export the voltage trace measured across the resistor to CSV, put it in a spreadsheet program, subtract the zero offset (idle level) and add all the numbers up.
    If the trace unit is volts and seconds, the result is volt-seconds. Divide by your resistor value and you get amp-seconds. Divide again by 3600 and you get amp-hours.
